No probs , time is scarce for everyone - thanks for replying ! Had a look at your build but maybe I missed
it - what size v-bearings /where did you buy them / what wall thickness is the tube/angle ?
I was thinking of 30mm*30mm*3mm for the tube - maybe even 25mm*25mm*2mm would be
good enough as the axis are manually moved - what do you think ?
Would you have any opinion based on your experience with v-bearings/steel tubes on
whether a horizontal plane mounting of the v-bearings may be workable since
it may make indexing easier (holes 32mm spacing in tube length/ indexing pin through carriage into holes) ?
(could put an indexing flat in the vertical plane
![Wink](images/smilies/wink.png)
- got to think out of the box
One other alternative as I mentioned would be to use stainless rod - not sure how
good that would be eg tacked on two sides of a square tube.
Just curious - you mentioned scrapping the router to make room for your mills - did you
opt for cnc adapting industry milling machines instead ?
