587,396 active members*
3,468 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Hard anodizing question
Results 1 to 6 of 6
    Sep 2008
    277
    I need to tap some holes in some 6061 and it need to get hard anodized. How big should I go with the oversized tap so I don't have any problems?
    Apr 2005
    1268
    Re: Hard anodizing question
    Why don't your just plug the holes?
    B
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Sep 2008
    277
    customer wants everything black hardcoat
    Jun 2009
    135
    Aluminum gets etched (cleaned) before anodizing, which removes some material. The anodizing adds about the same amount that was etched away. One H size on the larger should be plenty. There is a very informative post at this site on this matter including stress distortion problems from anodizing.
    Sep 2008
    277
    Quote Originally Posted by JimBoyce View Post
    do you know where it is located?
    thanks
    Aug 2011
    215
    Look up mil-a-8625 for the spec. Not sure if it has the thickness there but the anodize usually is .002" thick, where .001" of that eats into the material. So it is usually .001" off the original surface.
  1. Home Anodizing. Low Current Anodizing. 720 Rule
    By kreutz in forum Mass finishing equipment/media/strategies
    Last Post: 11-29-2019, 04:13 PM
  2. Hard Milling Question.....
    By philrose in forum Tormach Personal CNC Mill
    Last Post: 03-21-2013, 12:51 PM
  3. Anodizing question
    By levelzero in forum Material Machining Solutions
    Last Post: 11-12-2010, 02:04 AM
  4. Question about hard milling
    By AMCTony in forum Haas Mills
    Last Post: 08-31-2008, 12:26 AM
  5. Easy question, Hard solution
    By CBNDude in forum Mechanical Calculations/Engineering Design
    Last Post: 06-10-2005, 07:04 PM
