603,344 active members*
3,363 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Hard drive servo spindle are any good for home made lathe?
Results 1 to 6 of 6
Hybrid View
    Jul 2007
    78
    Hello people.
    Well, that´s the question: the spindle servo from hard drives is any good to use on the spindle of a small cnc lathe?
    I´m talking about the torque that they offer.
    Thanks people!!
    May 2007
    106
    don't know about torque but i've seen people using some as a grinder, juste sticking a piece of sand paper on it.
    You'll certainly need custom 3p drivers, as a hard drive max consumption is below 50W...
    and about their bearings, they are tiny, not supporting much radial and axial loads.
    but it could be a nice motor with matching controller for a HF spindle on a mill.
    aeromodelists often use them for their planes, I think they where talking of ~300W output after re-wiring they, and with a R/C controller.
    Jul 2007
    78
    Do you now about some page with or without pictures about those aeromodelist explain the changes?
    Thanks man!!
    May 2007
    106
    I'm afraid not, it was 1-2 yrs ago when I was looking for doing a RC plane.
    search for "brushless motor" ,"diy brushless motor", "diy brushless motor hard drive" etc. etc
    ex:
    http://www.bavaria-direct.co.za/ (300W from HDD)
    http://forum.gobrushless.com/
    RC controller (some should be modifiable): http://www.rcgroups.com/forums/showthread.php?t=140454
    Aug 2007
    162
    If you are still pursuing this, you'll want a ball bearing motor, which means a hard drive from '02 or earlier as pretty much all HDDs use fluid bearing motors now. FDBs tend to leak lube when spun backwards, and as was previously mentioned don't like axial loads. As for torque, if you're really interested I can get Kt/Kv specs for 12v/7200 rpm motors and 12v/15k rpm motors (I work for Seagate). They can spin up to those speeds incredibly fast, so I imagine there's decent torque potential for their small size. Also, you will either need to add a feedback device or find a good brushless dc motor controller.
    Jul 2007
    78
    tanks man.
    From the 30 or 40 hd disk i have found the last weeks, is one or two with some specification interesting for my project. I dont have the brand and model right now.
    About those Kt/Kv spects im interest!!
    i have something for feedback.
    Every thin you have for helping my is good.
    By the way the other day i found something wich blow my head.
    watch this:
    http://www.codeproject.com/KB/system...spx?print=true
    Floppy drives have stepper motors on it, and 1 controller to use for hour projects. I have tray that and it work!!
    Kcam program controll it like the best!!
    5 1/4 floppy disk drives also work and they are better because of the more powerfull motors.
  1. Home Made 4th Axis with Harmonic Drive Unit!
    By widgitmaster in forum Benchtop Machines
    Last Post: 08-27-2017, 03:16 AM
  2. Home Made internal spindle stop!
    By widgitmaster in forum Mini Lathe
    Last Post: 08-13-2016, 10:46 PM
  3. Home Made Mill/Lathe/Press (With Pics)
    By Hawkeye in forum Uncategorised MetalWorking Machines
    Last Post: 11-20-2006, 09:51 PM
  4. First tool for the tiny lathe (home made) pics
    By Stevie in forum Uncategorised MetalWorking Machines
    Last Post: 05-02-2004, 04:24 PM
  5. Home made lathe ideas
    By Hobbiest in forum Uncategorised MetalWorking Machines
    Last Post: 02-15-2004, 10:08 PM
