587,129 active members*
2,987 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Hardened steel tubes, suitable for frame cnc router ?
    Dec 2005
    313
    Hi :-)
    I have a few hardened steel tubes.
    Are hardened steel tubes suitable to make a frame for a cnc router?
    Hardening makes stress in the tube.
    Does this stress reduce over time?
    And does it lead to inaccuracies?
    Which results in a bend frame?
    Thanks.
    Jul 2005
    12177
    Quote Originally Posted by vroemm View Post
    Hi :-)
    .......Thanks.
    Yes, almost certainly.
    Does this stress reduce over time? And does it lead to inaccuracies? Which results in a bend frame?
    Probably no. As an example on some commercial machines the bedways are hardened and ground; similarly linear ball guides and ballscrews are hardened and ground and they do not change over time.
    Maybe yes, maybe no.
    There is no particular advantage to hardened tubes unless you are using them as the ways and running bearings along. That is the application where hardened material is preferable.
    The hardening does not alter the stiffness it simply means you can bend the tube and it will spring back where a soft tube might bend permanently. But provided you do not bend far enough to make a permanent bend both hard and soft bend equal amounts for equal force.
    There could be some disadvantages:
    Welding hardened tubes may not be a good idea as they could crack and the heat from the welding will certainly release some of the stresses and they will distort in unpredictable ways.
    Drilling hardened tubes is going to be difficult or impossible.
    Dec 2005
    313
    Quote Originally Posted by Geof View Post
    Good point.
    In my case there is a advantage:
    I have hardened steel tubes, i do not have normal steel tubes :-)
    I did not know this.
    I hoped it would increase the stiffness.
    That will probably be the deal breaker.
    Thank you very much for your knowledge :-)
  1. My Steel Frame Router
    By epineh in forum CNC Wood Router Project Log
    Last Post: 07-06-2009, 03:27 AM
  2. My 2nd Steel Frame Router
    Last Post: 07-12-2007, 08:35 AM
  3. Steel tubes
    By Stoneair666 in forum MetalWork Discussion
    Last Post: 03-31-2006, 02:19 AM
  4. Need recomendations on 2" square steel tube for router frame.
    By danm in forum DIY CNC Router Table Machines
    Last Post: 11-15-2005, 01:21 AM
  5. suitable frame for linear rails
    By daedalus in forum Linear and Rotary Motion
    Last Post: 07-13-2005, 09:48 PM
