I spent the morning at home making a new shaft for the piston in the turret check valve. Since I did not know exactly how long to make it I scaled the drawing in the maintenance manual and made it just a bit longer. Once it was done and installed I worked it back and forth and decided it needed to be a little shorter to work, but since I don't know exactly how it functions, it was just a guess. I also found that it was missing an O-ring. I stopped by the local hardware store and found one that looked like it would work.
I drove to work and installed the check valve and turret. It seemed to work properly, but the turret still would not drop down. After taking it apart several times and listening to the air leaks, I finally realized that there was an O-ring that was missing under the turret. I took one off my spare oil distribution block and installed the turret again.... it still did not work. Once again I took it apart and saw that I had forgot to install an O-ring on the upper piston, on the inside. Again I installed the turret and it finally worked! Since I was missing the screws that attach the tool plate to the turret, I was not able to completely test the indexing, but it looked close. On the way home I found some screws for the tool plate. They are 5/16-24.
With the turret now running, it was time to test the coolant system. I added the 5 gallons of Hangsterfers to the tank. That stuff is a mess. Almost like way oil. Since it was dyed red, it reminded me of 5606 aircraft hydraulic oil. I made of video of test. Kirk was correct, 5 gallons is not quite enough. After about 10 seconds of running the coolant, the pump started to suck some air. I guess I will have to get another 5 gallons.
[ame="http://video.google.com/videoplay?docid=-4750879927914238676&hl=en"]CHNC coolant test[/ame]
I posted a picture of the final coolant line from the stand to the manifold.
I have most of the mechanics of the lathe finished, now most of my time will be spent programming and working on the electronics. My PLC programming class was postponed a week so that may slow things down a bit. I received my hall sensors for my custom turret encoder so I will be working on that as well. If I can find a cover for the X-axis, that would save me some time making a custom one.
Vince
