603,959 active members*
1,843 visitors online*
    Jul 2004
    93
    Hardinge Chucker With Upgrade Tech Cnc
    Dose any body have any info on a cnc conversion from Upgrade Technolgy for a Hardinge lathe, I used one back in the late 90s and would like to retrofit my chucker.
    have been told UT no longer exsist but sure would like to find a table that they used , and then set up with a ajax controller
    thanks Brad
    IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH
    Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust.
    Mar 2003
    928
    Jan 2005
    1121
    Not to send you into the pits of hell, but there is a guy on alt.machines.cnc who is familiar with some of those style dealies.
    'Gunner', wicked militia type, but otherwise not a bad guy
  1. Using your CNC Mill as a CNC Lathe
    By lstool in forum Knee Vertical Mills
    Last Post: 06-12-2017, 02:29 PM
  2. Top Tech CNC Milling Machine from penn tool
    By wisp in forum Knee Vertical Mills
    Last Post: 03-29-2011, 12:43 AM
  3. CNC upgrade for grizzly G1006?
    By TheDudeVT in forum Uncategorised MetalWorking Machines
    Last Post: 08-04-2010, 07:27 PM
  4. Noob CNC Tech.
    By little_one in forum Uncategorised CAM Discussion
    Last Post: 02-02-2005, 01:28 AM
  5. Lagun HD V-2/Crusader II CNC upgrade help
    By plascom in forum Uncategorised MetalWorking Machines
    Last Post: 12-21-2004, 05:14 AM
