603,807 active members*
3,164 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Hardinge Conquest T-51 Lube System Failure
Results 1 to 5 of 5
    Oct 2012
    3
    I've been working towards getting this lathe up and running in our shop for the last few days and so far everything has gone well, but now I'm really stuck. It turns out a previous employee decided to take it upon himself to disassemble the lube system in an effort to diagnose and fix the "Lube System Failure" error. This puts me in a bad situation because now I have no idea how the lube system was originally wired. Would anybody that has this machine or a similar model hardinge with the bijur oil system be able to take a picture of the terminal block inside the auto oiler housing? This would at least give me a solid base line to begin troubleshooting the problem.
    Thanks in advance,
    Cameron
    Sent from my SM-N900V using Tapatalk
    Re: Hardinge Conquest T-51 Lube System Failure
    Hi, I have a Hardinge Conquest T51 with fanuc 18T. I don't have its maintenance manual.My machine getting alarm 1020 Chuck open. Can you please help me in this regard as you have same machine running. Thanks
    Cameron, I will send you wiring picture tomorrow morning for sure.
    Aug 2011
    34
    Usually you get the "chuck open" message when you try to cycle start the machine with the chuck open, which you can't do.
    May 2016
    533
    Probably got the machine set for internal or the hoses round the wrong way
    Manuals available if required
  1. Replies: 3
    Last Post: 03-14-2019, 03:24 PM
  2. hardinge conquest 51
    By mikemck in forum Hardinge Lathes
    Last Post: 11-16-2015, 02:33 PM
  3. Hardinge conquest 42
    By gyroxis in forum Hardinge Lathes
    Last Post: 09-21-2010, 02:07 AM
  4. Hardinge Conquest 42
    By newc in forum Hardinge Lathes
    Last Post: 02-25-2010, 01:10 PM
  5. Hardinge Conquest 42
    By cncdiag in forum Fanuc
    Last Post: 05-21-2008, 01:06 AM
