588,138 active members*
8,717 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Has anyone done 4th axis on Tormach and Fusion
Results 1 to 5 of 5
    Feb 2007
    27
    Hi Guys-
    Has anyone actually done 4th axis work on the Tormach since Fusion started supporting it? If so, what post are you using?
    Thanks!
    Matt
    Jan 2012
    58
    Quote Originally Posted by mattford1 View Post
    Hi Guys-
    Thanks!
    Matt
    Hi Matt,
    I assume that you are referring to the new 4th axis "wrapping" feature - rather than the 4th axis indexing capability, which has been around for awhile.
    If so, yes, I have attempted to use the wrapping features, with very unspectacular results.
    For my first attempt, I used the same post processor that I have been using for quite some time, which was modified (successfully) to support the 4th axis indexing functions. Results: success, sort of. I was able to create a gcode program that actually worked - cut a pocket on the surface of a cylinder - but had weird speed control issues. It looks like the inch per minute (ipm) speed are being processed correctly on X & Y axes, but in the A (4th axis) direction, the same number is being processed as inches per DEGREE (ipd). So, while 50ipm is reasonably quick X & Y moves), 50 dpm is really really slow.
    Second attempt, I tried loading the latest post processor from Autodesk (BTW I have a Tormach PCNC 1100 v3, with PathPilot controller). This time, things got decidedly worse. When I attempted to create a gcode program using the same setup that I previously used, I got an empty file. Zero bytes, no content.
    I posted on the Fusion 360 CAM forum about this yesterday, but have had no response.
    Anyone else tried to use the new 4th axis wrapping on a Tormach/PathPilot mill?
    Sent from my iPad using Tapatalk
    Apr 2011
    720
    Re: Has anyone done 4th axis on Tormach and Fusion
    I have tried this yet, but in the NYC CNC youtube video that John Sanders did on this update, he included a link to an A axis post processor. Maybe that would work better????
    Terry
    Feb 2007
    27
    Quote Originally Posted by MFchief View Post
    Terry
    I tried using the A axis one and I get an error code with Path Pilot regarding M11
    Sep 2009
    1856
    try this one I did it for someone 2 weeks ago it was fine for them.
    don't copy how john selected the wrap cylinder he got that bit wrong you select the bottom faces of the cut as the wrap cylinder and select dead center end as the origin.
    the velocity for the A axis you double its velocity if not more compared to your x or y velocity, it takes a bit of playing to get the velocity correct.
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
  1. Modified Fusion 360 Post for the Tormach Rapid Turn
    By mattford1 in forum Tormach Personal CNC Mill
    Last Post: 04-26-2017, 01:00 AM
  2. Tormach Fusion 360 Post - Why the M1's before tool change
    By KSky in forum Tormach PathPilot™
    Last Post: 08-18-2016, 07:51 PM
  3. Need some quick help, Fusion 360 CAM and the Tormach Lathe
    By David Bord in forum Tormach Slant Lathe
    Last Post: 03-17-2016, 05:50 PM
  4. Fusion 360 Post Processor for Tormach PCNC1100
    By Gerry Kmack in forum Tormach Personal CNC Mill
    Last Post: 02-05-2016, 04:48 AM
  5. Tormach Post and Fusion 360
    By grimms3 in forum Tormach Personal CNC Mill
    Last Post: 10-20-2015, 04:58 AM
