587,997 active members*
1,930 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > hass tool turret alignment problems!
Results 1 to 14 of 14
    Oct 2007
    6
    Hi! I hope some one can help me? I have a hass sl30 lathe and had a crash. It was kinda bad and threw out my tool turrent rotation alignment! argh. So i have the instructions from hass on how to fix my problem but when I enter
    m43 in mdi mode so I can adjust the coupler on the servo the turret goes out of alignment when I enter m44. It seems that when the turret is locked back in place it jumps the rotation back out. Can anyone help me?
    Doug
    Jul 2005
    12177
    Can I help? Good question...let me describe what I observed when we managed to crash the turret on a HL1.
    The turret is driven by a servo motor which indexes the turret into a position so that when it locks down the dogs are aligned. The servo is connected via a flexible coupling that clamps onto the shaft without any keyway. In our crash the spindle was not running but we had the turret too close so when it moved out to release the dogs it bumped into the chuck and when the servo tried to rotate it all that happened is the coupling slipped a bit and the servo overloaded and alarmed. After we had jogged things clear and tried a toolchange, because the coupling has slipped the servo did not rotate the turret into the correct position for the dogs to align so it could not lock back and gave a turret lock alarm.
    I watched the tech realigning things and this is what I managed to observe:
    The tech took off the top cover to expose the servo drive and coupling, loosened the clamp on the coupling, unclamped the turret with a G43 (I think), turned it to position 1 by hand, did a turret fwd command to T1, clamped the turret with a G44 and then retightened the clamp.
    Maybe somebody will come on with some more specific advise but this could help you if it seems to concur with the instructions you got from Haas. If not sorry I cannot help.
    Oct 2007
    6
    Yup, that's what I did to align it. I get the alignment perfect in x and in the turret rotation but as soon as I reclamp the turret back in place with the m44 it seems to jump the rotation off again! and its not a little it's like .090" so there is no way i can shim that. man this sux!
    Aug 2005
    578
    My SL10 got bumped awhile ago. I removed the top and loosened the coupler, turned the A axis motor with the jog handle and re tightened the coupler. Made a couple test cuts to make sure I was on center and buttoned it up. All was well.
    Aug 2005
    578
    There is a pin in the back of my turret that was not allowing the turret to seat and thus giving a turret clamp alarm. I M43'd the turret forward, jogged it to the correct position, and that worked fine. I have a PDF of the maintanance manual if you need it. It spells out the proceedure pretty clearly
    Oct 2007
    6
    That would be awsome! thankx alot i've sent you my email address in a msg
    thanks again
    Oct 2007
    6
    well it seems that I can align my turret fine, I follow the steps everything works great I get it all true but as soon as I clamp the turret back(m44) into place it jumps out of wack on the rotation again when i unclamp it (m43) it drops back to near perfect alignment!? anyone have any ideas if there is some thing else that i need to adjust?
    Jul 2005
    12177
    The dog clutch device that locks the turret when it is pulled back has tapered teeth and the turret is bolted to the end of the shaft it is on. It sounds like the turret has moved.
    I am guessing you aligned the turret to the spindle using a boring bar holder and the tapered teeth are close enough that they pull in so the turret does lock but the turret is rotated slightly when the tapers line up and this gives the misalingment after locking
    With the turret locked loosen the clamping bolts slightly and tap the turret into alignment then retighten them.
    Now it should move out of alignment when it unclamps so you have to go back and adjust the servo coupling again.
    Incidentally if you have the A axis load showing on the screen in the current commands page you might see it jump when the turret locks. This is because the servo is holding it in place but when the tapered teeth engage and rotate it slightly it moves the servo which tries to compensate and move back.
    Oct 2007
    6
    well that sounds about right... but when i loosen all the bolts on the turret face the turret is still locked tight i can't budge it a bit... even when the turret is unlocked it still will not budge.
    Jul 2005
    12177
    Quote Originally Posted by Doug D View Post
    Okay that puzzles me. I had to get one of mine realigned by loosening the bolts and it did move. The tech did use a big hammer and a block of brass and I guess the 'tapping' as I described it was fairly heavy. But this was on a HL1 so maybe the SL turrets are different; we have successfully avoided crashing our SL's so I don't know.
    Put a piece of bar in a big boring tool holder and be a bit of a gorilla with a big hammer ???? Make a mark so you can see any movement and hit it alternately both ways. Maybe before doing this take the bolts out one by one to check that none of them have a dowel shank.
    Oct 2007
    6
    well I unbolted both bolt hole patterns and gave it a good whack in both dirs. and nothing! this seems very crazy there has to be a way to take off the turret!?
    Jul 2005
    12177
    You are outside my limits now . There must be some way to take it apart; I wonder if it is simply corroded?
    Contact the Answerman on the Haas website.
    Aug 2005
    578
    Doug
    I'll have the maint manual in the mail to you in the morning.
    Mar 2012
    Quote Originally Posted by PBMW View Post
    Doug
    Hi PBMW!
    I have now the very same problem ... Do you think you could also please send me the maintenance manual of the SL-30? I don't know how the turret is inside and I'm a little affraid to do it in the dark!
    Thank you very much!
  1. Hass VF-1 work coordinate problems
    By 1strokedrs in forum Haas Mills
    Last Post: 05-11-2012, 05:43 AM
  2. sl-30 turret alignment
    By bowhunter in forum Haas Lathes
    Last Post: 12-06-2007, 03:49 AM
  3. Mazak Nexus 640 Tool Turret problems
    By chattwo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-21-2007, 05:27 PM
  4. Turret alignment problems
    By coquina in forum Haas Mills
    Last Post: 07-18-2007, 12:53 AM
  5. Micro drill adapters - alignment problems
    By buzzard in forum MetalWork Discussion
    Last Post: 02-01-2006, 02:58 AM
