Originally Posted by
SophieGirl
Medina, I am going through the exact same process and have been researching also. I am going with 18 AWG stranded 4 conductor (4 wires in one cable run) shielded wire for my motors. Make sure you get stranded and not solid, since solid will start breaking down with the movement of the wire over time as your table is moving. Stranded is much more flexible. You can use the same gauge wire inside of your controller box for your remaining connectors, but I have chosen to go with solid wire since it will not need to be flexible in the controller box. Hope this helped. Stacey
