Thank you. :-) this project has been going on for a long time, but I just dismantled the Lego prototype a few weeks ago, since I finally have started on building the real thing (tm).Originally Posted by rhino
It will about 5 times bigger than the Lego prototype. about 1200x810x610 mm working range (note the very high vertical clearance) total estimated weight: +/- 450..500 kg, mostly build from 50x50x5 angle-bar. It will be a moving table design, so it's almost 2x1200 mm long. the rail is 30 mm steel rod (drawn KV45, H9), supported (and adjustable) every 180 mm, both vertical and horizontal. I drilled and threaded the rod and glued in 52 pieces of M8 thread. The steel base frame is almost completed and i will be starting on the (moving) table soon.
http://jwstolk.xs4all.nl/mill.htm
my site could do with an update, but did you see the 2 AVI files on it ?
