![Quote](images/misc/quote_icon.png)
Originally Posted by
kentdesautel13
It's been a long process trying to get this compressor working correctly, but its finally working great!
I added a Acme Electric model A3015K0310B transformer ( Buck Boost Transformer ) to help get my voltage set closer to the safe voltage that the compressor was looking for.
The transformer ran around $600
I contacted the manufacture of the transformer and they gave me the correct wiring configuration to get our output voltage at aprx 234v
There are various wires inside the transformer and depending on how they are hooked up with get you to the desired voltage. ( the wiring configuration they gave me wasn't in the manual )
You can either raise your voltage or lower it depending on what wires you use on the inside.
This has now solved the issue of the over voltage alarms, and it has also solved the issue of the contacts chattering when they engage.
So we are good to go...
