603,850 active members*
4,751 visitors online*
Results 1 to 10 of 10
    Jun 2012
    111
    Having a random problem
    I spent the last week running a batch of parts. When it was all said and done, I ended up losing 20% of the parts, and I have no idea why.
    Before I started the batch run, I spent some time optimizing the gcode, and tweaking the feeds and speeds. Once I started the batch, I didn't change anything, other than to take the finished part out of the vise, and put a new blank in. Every once in a while, one of the tools would cut about .050" too deep, but on the next tool the Z height would correct itself. I would take that part out of the vise, put it in the trash, and the next part would run just fine.
    I'm at a complete loss on how to explain this. I hope some of you can contribute ideas.
    Tormach 1100 series 3, with ATC running on Mach 3.
    Feb 2006
    7063
    Sounds like very likely tool holder pull-out - a not-very-uncommon problem with the Tormach PDB it seems. I don't see what else could "correct itself" on the next tool, unless you're re-homing between tools. A position loss (lost steps) would persist until the machine was re-homed, and would also likely get worse as time went on.
    Regards,
    Ray L.
    Dec 2012
    161
    I agree with Ray, sounds exactly like pullout.
    Best Practices for Preventing Collet Slip « Milling Around
    Try tweaking the pressure on your PDB. Are you running with flood coolant? I've had pullout caused by coolant splashing tool shanks in the ATC.
    The tormach white paper on preventing collet slip does a good job explaining all the issues and how to prevent it.
    Feb 2008
    389
    Sperman, not sure what you mean by " I would take that part out of the vise, put it in the trash, and the next part would run just fine." Do you mean when the part is finished you QC it and see the .05" over depth cut, toss it and put a new part in and run from the beginning, not changing anything and the next part runs fine?
    Would it be tool pullout if the next part runs fine?
    Gerry
    Currently using SC7 Build 1.6 Rev. 64105
    Jan 2010
    251
    Quote Originally Posted by Gerry Sweetland View Post
    Gerry
    Good point if he changes nothing except the part in the vise, a tool that pulled out is not going to magically reset itself.
    walt
    OP, has "Tormach 1100 series 3, with ATC running on Mach 3."
    ATC would be changing tools so the problem could come and go??
    David
    Jan 2010
    251
    Quote Originally Posted by David C. Allen View Post
    David
    good point too if he is using the atc and changing tools. more data is needed. are multiple tools being used, if so what tool is causing the problem, is the toolholder itself the problem, ie shank undersize maybe?
    Jun 2012
    111
    Quote Originally Posted by SCzEngrgGroup View Post
    Regards,
    Ray L.
    Thanks Ray. I wasn't able to come up with an explanation that makes any sense, but yours does. I'll have to check the torque on my draw bar. I probably need to check the collet fit also. I know several people have mentioned that it only touches at the very end on their machine.
    Feb 2006
    7063
    Quote Originally Posted by sperman View Post
    Also check the toolholder forks on the ATC - if one is loose, the tool will not be fully inserted into the spindle. If it were me, I'd sit and watch the thing, and stop it BEFORE each toolchange. When it stops, measure to see if the last cut was out of spec. If it is, then look at the toolholder, and see if it's fully seated in the spindle. Also watch and make sure each tool is fully inserted when the toolchange completes. If you do this, you should see if the problem follows a specific tool, or a specific ATC "slot", etc., ,or if the problem occurs when the tool is loaded, or due to pull-out. A few simple test programs doing heavy cuts with various tools should prove the point one way or the other. I'll bet you find the problem within an hour.
    Regards,
    Ray L.
    Jun 2012
    111
    I'm pretty sure I know which tool was having the problem, I just couldn't figure out why. Thanks again for the help.
  1. Random Z
    By atypicalguy in forum MadCAM
    Last Post: 03-28-2012, 02:07 AM
  2. Random G540 problem
    By Odie9 in forum Gecko Drives
    Last Post: 03-05-2012, 11:49 PM
  3. random tool-changer problem
    By hicarbon07 in forum Community Club House
    Last Post: 08-28-2008, 12:00 AM
  4. random thought
    By 2muchstuff in forum DIY CNC Router Table Machines
    Last Post: 02-16-2005, 04:46 AM
