587,531 active members*
3,549 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > having trouble getting this to cut right
    Dec 2003
    8
    Question having trouble getting this to cut right
    i am making a part and have trouble getting it to cut the part out with bobcad 17, i created the part and when i go to create the gcode it doesn't machine it properly, i am also have a problem with island surfacing. the material is .375 plastic rod. i have it mounted on an 3c collet chuck bolted to my mill table. the endmill is .119 flat endmill. maybe someone could try it out, i am machining it on my homier mini mill and using maxnc software. thanks mike
    Attached Files Attached Files
    :BANNANA:
    Apr 2005
    1194
    Are you trying to make this as a boss? Could you program the square part after you mill the top? Looks over complicated and has too many entities for what it is
    Dec 2003
    8
    the square part is the top and it needs to be in the middle of the 3/8 rod for proper fit. yes i guess you could say its a boss. mikenln
    :BANNANA:
  1. Kcam Cut depth
    By 47MLB in forum Uncategorised CAM Discussion
    Last Post: 01-18-2012, 08:04 PM
  2. Having trouble cutting aluminum sheet
    By fastturbovet in forum MetalWork Discussion
    Last Post: 06-15-2005, 04:33 AM
  3. rotary 4 ax depth of cut q.
    By nervis1 in forum Mastercam
    Last Post: 03-24-2005, 11:34 PM
  4. cut single, cut auto and cut all???
    By fastolds in forum BobCad-Cam
    Last Post: 10-06-2004, 02:15 PM
  5. PICS - BOAT HULL CUT WITH CNC
    By ninewgt in forum DIY CNC Router Table Machines
    Last Post: 08-03-2004, 12:21 AM
