I have a 1998 Hawk 40 that is incurring a higher load on the Y axis. I've had the machine one year and when I first got it, the load was not an issue, but over time, it has increased.
I do not run the machine on a regular basis. I also do not run the warm up cycle when I do use it and now I'm wondering if that might be part of the problem. Does running the warm up cycle activate the lube pump more frequently while running? I've already replaced the way lube manifolds thinking maybe some of the metering vales were clogged.
Any insight or help would be appreciated.
Tom
