588,633 active members*
6,047 visitors online*
    Feb 2007
    9
    heat treating
    Anybody remember the temp for heat treating h-13,S-7, 4140
    I thought for H-13 the temp was 1750 for 4 hr min and 1 hr for ever inch.
    I do not rember the temp for the draws I'm looking to get approx 46/48 rc.
    1150 1st, 1130 2nd, 1100 3rd,???
    for the S-7 ??????????
    Mar 2007
    10
    The book we have lists S-7 and H-13, 4140 is not listed. We use S-7 almost exclusively and normally draw back to a much higher Rockwell than you are talking about. Our book lists the following for S-7:
    S-7 - Preheat 1200-1300F, Heat Treat 1700-1750 @ 1/2 hr per inch, Draw at 1100 for 48.5 Rockwell C. We usually draw at 525 for our injection molds leaving us with a Rockwell of about 54.
    H-13 -Preheat at 1400-1500 until soaked completely. Heat treating at 1750 will yield approx. 48.5 Rockwell, they suggest min. time of 30 minutes for first inch and 20 minutes for each additional inch in max thickness. The draw temps you list for your H-13 appear to be real close. On the chart they show you are working at the high end of the temperature range the hardness drops from a high at 1100 of 52-54 down to 42 at 1200.
    Hope this helps.
    Jun 2007
    http://www.matweb.com/search/Specifi...bassnum=M4130C
    that site may help you or this one
    http://www.steelforge.com/alloys/?alloy=4140
    i my self would like chart on the tempering temps with the diferent hardness on 4140
    hope the links help
  1. heat to chip?
    By try in forum CNC Tooling
    Last Post: 12-15-2006, 04:35 AM
  2. heat to chip?
    By try in forum Mastercam
    Last Post: 10-10-2006, 03:14 AM
  3. Heat treating A36 MIG welded frame
    By ad_bfl in forum Mechanical Calculations/Engineering Design
    Last Post: 09-05-2006, 08:07 PM
  4. Picstep and heat
    By Agro in forum CNC Machine Related Electronics
    Last Post: 05-18-2006, 07:41 PM
  5. Heat treating question...
    By Chris D in forum MetalWork Discussion
    Last Post: 04-22-2006, 10:07 AM
