603,783 active members*
2,605 visitors online*
    Oct 2011
    Heidenhain ERM 280
    Hi, I am trying to install a ERM280 encoder onto a QAN 200UH motor. After assembling all the wires, I try to run the spindle and get a "8C00 Encoder on speed input S is defective". After adjusting the encoder, I was able to get the spindle to run however it occured again. I was wondering if anyone know what the reason is, and how to set the encoder proper if that is the reason. thanks.
    Dec 2008
    239
    are u able to measure The strobes?check the 5V TTL supply Feed back cable also
    regards
    [email protected]
    attention mr. prabhat
    i read that u have some exp on er 280 heidenhain trouble shooting. cud u pass me your contact details .
    i have a erm 280 rotary encoder on the B Axis, function is workhead for cylindrical grinding as well as indecing etc.
    Some oil was found in the wiring area and the encoder area. We have cleaned both throroughly. however we are not sure if the reader is entirely clean because we did not want to risk alignment by dismantling it.
    still the encloder generates following alarms:
    1. Pulse Miss (int)
    this then leads to a Over Current Alarm (OVC)
    this happens when we start the machine and press jog button. note the B axis button has still not been pressed. it tries to move as soon as jog is pressed.
    2. If it Jogs for a couple of rotations it then slips rotates very fast momentarily and genarates B Axis excess error.
    Any idea what is causing this and remedy.
  1. Heidenhain TNC 530
    By Matth3w in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 06-18-2010, 07:16 AM
  2. Heidenhain DRO
    By mmri1 in forum Bridgeport / Hardinge Mills
    Last Post: 10-27-2009, 04:34 PM
  3. heidenhain DRO
    By mmri1 in forum Uncategorised MetalWorking Machines
    Last Post: 10-20-2009, 02:58 PM
  4. HEIDENHAIN 151 TNC
    By lazerracing in forum Bridgeport / Hardinge Mills
    Last Post: 10-03-2008, 01:02 AM
  5. Heidenhain 150 help
    By tom bryant in forum MetalWork Discussion
    Last Post: 05-19-2006, 03:53 AM
