587,158 active members*
3,010 visitors online*
Results 1 to 4 of 4
    Dec 2006
    Question Heidenhain iTNC 530 G200(pecking cycle)
    Does anyone have information on how to program a pecking cycle (G200) on a tilted work plane?
    I am trying to define this peck cycle on a FPT machine with a rotating head. I am trying to use G80 to set my working plane but when the drill enters and retracts out of the hole it is not makiing a linear move that follows the axis of the drill.
    Attached Files Attached Files
    Sep 2005
    10
    Looking at your ISO program it doesn't look like your drilling on a tilted plane, but drilling in 5-axis. I believe the drill cycles only work when you define a work-plane. You'll probably have to have your post put out all drilling moves longhand. Good luck!
    You seem to have major problems with your posted program.
    1. Don't use m128 while drilling thats for "tool center point managment".
    2. use g80 to set the work plane
    3. call the drill cycle after you've defined it using m99 or g79
    ie
    N7 G00 X+0 Y+0 A+0 C+0 G40
    N8
    N9 M03
    N10 M08
    N100 G200 Q200=+.01 Q201=-1.25 Q206=+30 Q202=+.01 Q210=+0 Q203=+0 Q204=+3 Q211=+0
    N11 G00 X+0.0175 Y-3.1286 A+14.951 C-37.672
    G80 A+14.951 C-37.672
    M99
    N14 G00 X+0.5914 Y-3.883 A+18.661 C-36.182
    G80 A+18.661 C-36.182
    M99
    N17 G00 X+0.6207 Y-4.95 A+23.97 C-38.417
    G80 A+23.97 C-38.417
    M99
    also check that your tool/head has enough clearence when it rotates to the new positions
    Jul 2008
    7
    Spatial
    Why don't you guys use Plane Spatial ? That's very smart !
