587,675 active members*
3,544 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Heidenhain TNC 620 postprocessor
Hybrid View
    Dec 2010
    Hello.
    I`m trying to make a post-processor for my milling machine, which uses Heidenhain TNC 620 controller. I need some help with drilling cycles. Code looks like this:
    Code:
    81. Standard drill canned cycle.
    	seq_only,g_canned_cycle,"200 DRILLING ~"
    	"Q200=",force_no_add_spaces,initial_plane,default_add_spaces,comment_start,"SET-UP CLEARANCE ~"
    	"Q201=",force_no_add_spaces,drill_depth,default_add_spaces,comment_start,"DEPTH ~"
    	"Q206=",force_no_add_spaces,canned_feed_rate,default_add_spaces,comment_start,"FEED RATE FOR PLNGNG ~"
    	"Q202=",force_no_add_spaces,drill_depth,default_add_spaces,comment_start,"PLUNGING DEPTH ~"
    	"Q210=0",comment_start,"DWELL TIME AT TOP ~"
    	"Q203=",force_no_add_spaces,zero_position_z,default_add_spaces,comment_start,"SURFACE COORDINATE ~"
    	"Q204=",force_no_add_spaces,reference_plane,default_add_spaces,comment_start,"2ND SET-UP CLEARANCE ~"
    	"Q211=",force_no_add_spaces,dwell,default_add_spaces,comment_start,"DWELL TIME AT DEPTH"
    The problematic part is:
    Code:
    Drill depth is negative value, and my controller need a positive one after Q202. Everithing else is OK. Anyone knows how to make that value positive?
    My workaround for now is to change the processed code manually, but I would like to avoid that.
    Thank you.
    Oct 2006
    173
    Positive drill depth.
    Change the drill_depth variable to abs_drill_depth.
    This will output the positive number.
    Dec 2010
    I just came from shop and abs_drill_depth works perfectly.
    I found this morning, that there is PostVariables.txt file in post-processor directory. Which lists and explain all variables you can call from Bobcad.
  1. Heidenhain TNC355 postprocessor
    By vasyl markiv in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-19-2022, 11:46 AM
  2. need postprocessor for hypermill to heidenhain itnc530
    By stripper in forum Post Processor Files
    Last Post: 07-17-2011, 10:18 AM
  3. Replies: 3
    Last Post: 06-28-2009, 01:13 AM
