586,052 active members*
4,008 visitors online*
    Feb 2019
    Heidenhain tnc360 TOS fvp30cnc
    Hi.
    A question.
    Got an TOS fpv30cnc, with tnc 360 controller. Witch have som issues with parameter and plc program lists.
    Is it posible for me to retrofitt this old machine with some cind of new hardwere.
    Thinking PC baced controller?
    Ben Are
    Sep 2012
    216
    Re: Heidenhain tnc360 TOS fvp30cnc
    Anything is possible if you are prepared to spend the money. Have you reloaded the machine parameters to try and sort out the current problem?
    Regards Bob
    Jan 2021
    Hi ,
    I bought a Tos Fng 63 cnc machine with Heidenhain Tnc 360 controller.
    Machine parameters are set all to 0 . Im missing the complete parameters to download them in order machine to start working again. I cannot moove manualy . Im changing some parameters but the are not saved after shut down. Batery block seems to have power (5v) .
    Is there a chance somehow to find a solution with this complecate situation?
    Thank you
  1. Heidenhain TNC2500 or TNC360 post
    By santosa in forum Post Processors for MC
    Last Post: 06-18-2009, 09:14 PM
  2. Replies: 1
    Last Post: 06-15-2009, 09:21 PM
  3. Heidenhain TNC2500 or TNC360 Teksoft Post Processor " G " code ISO
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 06-11-2009, 05:51 PM
  4. Help with pp for Heidenhain TNC360
    By adrenal in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-07-2007, 04:01 AM
