603,370 active members*
3,844 visitors online*
Results 1 to 8 of 8
    Feb 2005
    117
    Helical interpolation- Mach 2 or Mach 3
    Does mach2 or 3 support helical interpolation for boring a hole on a vertical mill? If so where can I get information on doing this and also possible examples of.
    I need to bore a hole at 2.250" dia. by 4.000".
    Can I get a similar finish as with a boring bar without the step down mark.
    thank you
    Nov 2012
    1283
    Re: Helical interpolation- Mach 2 or Mach 3
    Yes, Mach3 perfectly understands 3-dimensional arcs. Here is an example of a hole cut in spiral motion:
    G0 X-11.5 Y0.0
    G3 X-5.75 Y-9.9593 Z-0.1667 I11.5 J0.0
    G3 X11.5 Y0.0 Z-0.5 I5.75 J9.9593
    G3 X-5.75 Y9.9593 Z-0.8333 I-11.5 J0.0
    G3 X-11.5 Y0.0 Z-1.0 I5.75 J-9.9593
    G3 X-5.75 Y-9.9593 Z-1.1667 I11.5 J0.0
    G3 X11.5 Y0.0 Z-1.5 I5.75 J9.9593
    G3 X-5.75 Y9.9593 Z-1.8333 I-11.5 J0.0
    G3 X-11.5 Y0.0 Z-2.0 I5.75 J-9.9593
    G3 X-5.75 Y-9.9593 I11.5 J0.0
    G3 X11.5 Y0.0 I5.75 J9.9593
    G3 X-5.75 Y9.9593 I-11.5 J0.0
    G3 X-11.5 Y0.0 I5.75 J-9.9593
    G0 Z0.0
    What CAM program are you using?
    May 2015
    1422
    Erm...
    It understands simple helices with the circular component on one of the planes XY, YZ, XZ and an orthogonal straight component along which to stretch the helix - as per your example, CoD, with the circular component in XY and stretching out through -Z.
    But try and do a general 3D arc with I, J and K components like my post tried to generate for a helical lead-in to a pocketing operation before I figured what options to switch off. You get a big fat "Nope" from Mach3 as soon as the curve leaves the current operating plane as selected by G17/18/19.
    Academic only for this question though - per your example for a helical mill straight down through the Z axis it works fine. Do it as a series of G2 or G3 moves, keep them under 180º per move, and add a Z component to each move. It will run each arc and push in on Z proportionally throughout.
    Nov 2012
    1283
    OK, I see the difference now. Fortunately, as you said, true 3D arcs are not needed for what the OP is trying to accomplish.
    May 2015
    1422
    I only jumped in because I remembered what a mongrel of a time I had getting it sorted out, don't want anyone else to ever have to go through that...
    Mar 2003
    35494
    It works fine with full 360° moves.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2015
    1422
    My bad, I was thinking of 180º causing issues when using R instead of I,J.
    Feb 2005
    117
    Thank you all for the response. As far as program (cam) that I am using is Bobcad. After seeing the examples it seems
    pretty straight forward.
    Will probably be trying out after lunch.
    Thank you.
  1. helical interpolation help.
    By albeens in forum Uncategorised CAD Discussion
    Last Post: 07-14-2014, 11:52 AM
  2. Helical Interpolation in V14.2 Pro
    By squarewave in forum CamSoft Products
    Last Post: 07-27-2013, 04:11 AM
  3. Helical Interpolation
    By eliot15 in forum GibbsCAM
    Last Post: 09-18-2011, 03:40 PM
  4. Replies: 3
    Last Post: 05-14-2010, 09:16 AM
  5. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
