Hi all,
We’re a small manufacturer of our own products and I usually frequent the HAAS forum (we have a 2009 VF3ss). I’m looking to manufacture a clear lexan helmet visor and would like comments on our initial thoughts. We have no experience with vacuum forming but I have read several posts on this forum and there seems to be a wealth of knowledge.
Our idea is to initially make the home made style vacuum former to make sure the whole process will work. And this hopefully will give me the ideal stock size so we can build the machine the correct dimensions (as small as practical to avoid wasted material without sacrificing part quality).
Ok so here is the basic info,
2mm lexan material
Part size is approx 300mm x 175mm x 100 deep
I have access to a vacuum pump (see photo, we use it to hold down lexan for machining at the moment).
We’d like to build a machine similar to the Stelter unit but a custom size (we will only make one part)
Questions,
Starting with 2mm material, how much thinning would you expect over the more vertical sections? (roughly from experience).
Will this vacuum pump be sufficient?
Will a super polished tool give the best optical results? (I read that smooth surfaces could affect the vacuum draw over that section).
Is aluminum a good tool material or is a plastic tooling board better?
Please if you can see any obvious flaws in the plan just let me know.
Frogger
