603,936 active members*
2,244 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Help with acme stub thread calculation--Please
    Feb 2012
    I have a project with two mating parts with a 1 3/4"-8 Acme stub 3G thread. I do not have gages or the correct tool but I do have a regular acme tool with the 29 deg included angle.
    The external thread is 1.750/1.7437 od, and 1.7045/1.6959 pd. How can I check the pd on this. Is there a MOW? Wire size? If the tool angle is right, cant I just control the minor dia? This is what I would like to do but don't know what that dimension is. Its probably in the handbook, but I don't have it right now. For the external thd, I need two things please.....
    1. The thread minor dia
    2. The width of the land at the thd root(for stub thd) plus allowance if possible. I can compensate in my program to widen to correct dimension.
    The internal thd--the print says 1 3/4"-8 stub acme -3G BD1.675/1.681 minor dia. I am not sure what the BD means-sounds like those are the minor dimensions.
    3. What is the width of the land at the major dia of the internal thd(plus allowance if possible).
    If I can make the OD thd correct, I can use it as a go gage on the other part. Any other ideas for checking the ID thread.
    I know there are a lot of smart guys in here-please help me with this. It is a hot prototype for an important customer.
    Thank you.
    May 2004
    4519
    If you send me some money I can tell you where to look it up.
  1. stub acme
    By roncnc in forum Uncategorised MetalWorking Machines
    Last Post: 04-16-2011, 12:30 AM
  2. anyone cutting Stub Acme threads?
    By WOLOG in forum MetalWork Discussion
    Last Post: 11-19-2010, 01:24 AM
  3. Threading Stub Acme M2
    By KDWIENS in forum MetalWork Discussion
    Last Post: 09-01-2010, 09:15 PM
  4. Acme Thread Calculation
    By Rally in forum MetalWork Discussion
    Last Post: 12-18-2009, 07:23 PM
  5. can stub acme be changed to acme
    By osiris999 in forum MetalWork Discussion
    Last Post: 01-28-2009, 09:00 AM
