587,948 active members*
4,493 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Help! Advice needed to convert stepper to servo!
Results 1 to 8 of 8
    Oct 2005
    6
    Hello:
    I am wanting to convert my stepper-run mill to a servo-run. I am a teacher, and have a very limited budget (around 1000), and do not want to make any mistakes with the public's money!
    Questions:
    1. How mush power/torgue do I need? We ONLY mill 1/8" thick soft plastics (Sintra) in 2D shapes. I ONLY want to move at 100 IPM speeds? (By the way, is it safe to go that fast and reverse directions????)
    2. Can I simply bolt the new motors on the old NEMA 23 base holes? I thought I read about having some kind of adapter/coupling?
    3. Can I mount a dial on the z axis which would allow my students to carefully lower the bit to the work surface. We do a lot of fine engraving, and I think this would help.. Can you "spin" servo motors without damaging them?
    4. Anyone know a person (or company) who will sell me a plug and play system for about $1000?? I need them to be a fully-licenced business entity or the school district will not pay out!
    Thanks. If you have answers, please either post them here or better yet email me directly at "[email protected]"
    Sep 2003
    552
    I have the small CL system and have used it with the CNC control software included and with Mach 3 demo software with good results.
    http://www.maxnc.com/page13.html
    Darek
    Mar 2003
    270
    What size is your mill? What is the leadscrew pitch?
    Fred Smith - IMService
    http://www.cadcamcadcam.com.hobby
    Sep 2004
    32
    If you want the least expensive solution, try building your own.
    I hope not to be too self serving, but you can find a pretty good little book to answer your questions and be a good reference for your students, right here at CNCZone classifieds. There is a section on calculating torque and related formulae, drivers and how to build a simple Z axis, plus where to get free CNC operating systems, write G-code and make the machine work. You can probably get the whole thing built and running for under $300. To see more click on this URL
    http://www.cnczone.com/classifieds/s...&cat=11&page=1
    Good luck.
    -Mark
    Feb 2004
    813
    I think you guys are missing the point; he wants to change what he has; not build a new system from scratch
    Apr 2004
    678
    Quote Originally Posted by designit
    You need to give more information! What size is it? Make, model?
    The torque that will be fine for an Emco F1 will not be able to move a Bridgeport at all. When reversing you need to go through zero speed. Any other way would involve infinite acceleration.
    As an example, you have several motors to choose among from this manufacturer.
    http://www.worldservo.com/html/as.htm
    The price for 3 motors + 3 drives from this manufacturer will go beyond your budget unless they have a special deal for schools.
    Yes, but you may damage the drive unless the rotation is very slow. And you would of course have to disable the drive or it will oppose your moving the motor.
    It seems that if someone that price their time as a professional would leave very little for the cost of hardware after charging for their time.
    Have you considered just modernizing your stepper system? If it's based on an old non-chopping driver, there is a lot of performance (speed) to gain by just changing the driver(s) to a modern microstepping chopper design.
    Mar 2005
    3
    cheap servo drives
    there is a company that has very inepensive servo drives they typically have a torque of around 280oz.in which should be enough for what you are doing.You will require to do some software however it is not rocket science and would even give your students some experience with machine code....I also know that there is some software out there that will help you.
    check out their web site:http://www.coolmuscle.com/Motors
    I am neither affiliated with this company but have used their product in machine applications and consider their product to be very robust
    Pete Nielsen
    Aug 2004
    2849
    ...so, you got something working with a stepper....and you want to be frugal.....why do you want to switch to a servo for the application you stated??
