Help! Another Chinese 2.2KW Inverter Isssue
I'm in the process of switching from a Porter Cable Router to a 2.2KW Chinese spindle and I can't get the drive to respond to the speed and spindle command from Mach. I'm using the PMDX 126 board with their 07 speed controller and a smooth stepper. I've configured the drive, mach and the smooth stepper to what I think is the correct configuration.
Info!
Drive: Huanyand Inverter 2.2 KW model HY02D223B using 220V single phase input and 0-400Hz output. The spindle works OK using the run key on the front panel.
When I change pD001 to 1 for external terminal command the pd002 to 1 I can't get the drive to work even though I have the correct voltage out of the PMDX card (0 - 10V = 0 - 20000 RPM) and the input of the VFD is ACM (common ground) and VI (voltage in). Also the jumper J1 has been put on pins 1 and 2. Pd070 (analog input) is set for 0 (0-10V) adn the other settings have been made for my 0 - 400 hz drive.
Any ideas?
Bill
billyjack
Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
