587,669 active members*
3,429 visitors online*
IndustryArena Forum > Community Club House > International / Regional Forums > USA Club House > HELP! Anybody have a Gerber Advantage 400 (AR400) CNC router?
Results 1 to 4 of 4
    Feb 2013
    I have a Gerber Advantage 400 also known as the AR400. It is old and not supported by Gerber. I do not have the software to run it so I am looking for the software. Does anybody know if it will run with Omega 5 CS? I have been told the software does list my machine but Gerber hasn't tested it so they won't guarantee it will work (actually they don't even like to talk about it, AR400 seems like a bad word to them). Before I spend the BIG MONEY on the software I would like to know if anybody is running one of these with Omega 5 or any other version for that matter. What software are you running? I have also been thinking about looking into the cost of doing a retrofit instead of making the investment of proprietary software. Any suggestions would be greatly appreciated....
    Aug 2005
    158
    Re: HELP! Anybody have a Gerber Advantage 400 (AR400) CNC router?
    I just finished retrofitting this machine to mach 3 control. You will need artpath if you want to use Omega to run it. I do like Omega and use the software with my Edge/hs15 but for running a cnc router it's rather lacking. The retrofit was an easy decision for me because the original controller was dead. I just bought my machine from a local Signarama. Gerber won't service the machine anymore so I got it for a steal $400 bucks. It cost me less than $400 to retrofit the entire controller.
    Here's a vid of the retrofit:
    www.decalpro.ca
    Feb 2013
    Quote Originally Posted by pimpbike View Post
    Thanks for the reply and doing a video on this retrofit. I haven't seen anything on these machines so your video was a first. It is very hard to find information on the AR400 routers. Please let me know when you have another video to show.
    Aug 2005
    158
    Did my 1st cut on the ar400 today. Was waiting for a 1/2 to 6mm adapter sleeve for the V carving bit I had. Cut perfect with no issues.
    www.decalpro.ca
  1. My Gerber Dimension 200 router needs help!
    By markrobertsigns in forum Want To Buy...Need help!
    Last Post: 04-02-2010, 12:16 AM
  2. Weight of Gerber AR400?
    By scoop113 in forum Commercial CNC Wood Routers
    Last Post: 10-06-2009, 07:33 PM
  3. Bobcad + Gerber router
    By Vigilance in forum BobCad-Cam
    Last Post: 01-22-2008, 08:18 PM
  4. Gerber AR400
    By steve_p in forum Gerber
    Last Post: 11-04-2006, 02:44 AM
  5. Gerber Router III?
    By Zephrant in forum CNC Machining Centers
    Last Post: 09-17-2003, 05:58 AM
