HI I am having trouble here, I want to cut a simple slot 20mm deep 3 mm at a time, when I use auto-cut it works but always returns to safe Z with each pass. Is there a way to make it Z up 1 mm above the last pass? Also is there a way to make it cut in both directions. I am only using mdf right now.
PS. I know this can all be done using Single-Cut it just takes too long
thanks
