603,969 active members*
3,133 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Help with Bridgeport Series I with Textron controller?
    Jul 2007
    3
    Hello-
    I am a noobie here and have been reading a lot of posts here today. A friend of mine who has a small shop has just received two Bridgeport Series I mills with the Textron logic unit. Both have ADR BTR's hooked into the Textron.
    My friend is a great machinist using manual operations but has absoluely no computer knowledge whatsoever. I have been tasked with getting this things up and running. I have a lot of computer experience and am experienced in AutoCAD drafting while having no machining experience.
    What would it take to get these machines up and running and ready to program? I learn very quickly but so far I am still in the dark on a lot of things. Any info on software, cables, computers, etc. would be greatly appreciated.
    Thanks for your time!
    Ross
    Jul 2007
    4
    I am also in your same situation but forgive my green questions what is ADR BTR stand for ? Have you run single lines of code in the manual data input yet ?
    Jul 2007
    3
    Hello-
    That is short for the Advanced Digital Research Behind the Tape Reader which replaces the paper reel tape system.
    I will be trying the machine out on Tuesday when I go to my friend's shop.
    Ross
  1. Help w/Bridgeport series1 textron CNC
    By MrHorsepower in forum Bridgeport / Hardinge Mills
    Last Post: 02-10-2010, 08:49 AM
  2. Need Schematic/Information for Bridgeport Textron DRO
    By hwerner in forum Bridgeport / Hardinge Mills
    Last Post: 02-15-2007, 09:03 PM
  3. Bridgeport Series I Boss 5 Controller
    By VIC H in forum Uncategorised MetalWorking Machines
    Last Post: 07-24-2006, 05:54 PM
  4. Bridgeport Series 1 CNC ID
    By markhas in forum Bridgeport / Hardinge Mills
    Last Post: 05-30-2006, 04:06 PM
  5. Bridgeport Series 1
    By CRAZYRICH in forum MetalWork Discussion
    Last Post: 07-28-2005, 01:54 AM
