603,311 active members*
2,084 visitors online*
IndustryArena Forum > Hobby Projects > Musical Instrument Design and Construction > Help in Carveco Maker - Les Paul neck Pocket carve
    Apr 2025
    New to the site and I'm looking for some help.
    Im currently using Carveco Maker to do the CNC work on a Les Paul body. I model in Autocad, and then import the .dwg into Carveco. the problem I'm having is getting the slope of the bottom of the neck pocket. I know the correct angle, but whenever I import the model, it flattens the bottom of the pocket. What am I doing incorrectly? I have tried inserting the entire model, and just the pocket, and noting io seem to be doing works correctly.
    Let me know if I need to clarify any part of the process.
    And thanks in advance for the help.!!
    Nov 2014
    716
    Re: Help in Carveco Maker - Les Paul neck Pocket carve
    You might need to upload the file so someone here can try the same thing, unless it's a proprietary file.
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
  1. Trouble with cutting les paul neck pocket
    By eriedel in forum Musical Instrument Design and Construction
    Last Post: 06-12-2013, 05:23 PM
  2. New Les Paul
    By LiquidGuitars in forum Musical Instrument Design and Construction
    Last Post: 08-02-2012, 03:05 PM
  3. Les Paul type neck machining?
    By PuresoundGuitar in forum Musical Instrument Design and Construction
    Last Post: 05-21-2010, 09:11 AM
  4. Les Paul
    By prle in forum Musical Instrument Design and Construction
    Last Post: 11-16-2008, 11:36 PM
  5. My Les Paul neck
    By Jer7440 in forum Musical Instrument Design and Construction
    Last Post: 05-29-2007, 12:20 PM
