603,982 active members*
2,664 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Help creating Passes with Goaround command?
Results 1 to 5 of 5
    Mar 2006
    22
    im using the goaround command so i can create tabs, not using the menu to the side to use contour. how do i make it create extra passes as opposed to one single cut? i could just be blind but is there an option? thank you
    Nov 2004
    320
    set cut depth in define tool i.e. 3mm for a sereis of 3mm deep passes
    Mar 2006
    22
    so if you define the tool as a certain depth you wont have to create extra passes in the options window of the contour as well? if so thats pretty cool. thanks
    Nov 2004
    320
    yup
    you tell it the tool wil cut in 2mm passes in cut depth in tool def
    then it will only cut a max of 2 mm in one go
    if your part is 1.5 mm thick it will cut at 1.5 mm even tho you give a cut depth of 2mm
    hope you understand that :-)
    Mar 2006
    22
    thank you
  1. how to change the passes in turning
    By joachim in forum FeatureCAM CAD/CAM
    Last Post: 10-17-2012, 06:46 AM
  2. Both Conv/Climb Passes on Line Art
    By MichaelHenry in forum SprutCAM
    Last Post: 09-04-2007, 03:16 PM
  3. Lazycam doesn't generate "passes"
    By wadero in forum Mach Mill
    Last Post: 08-21-2007, 10:22 PM
  4. what is the same command?
    By hop in forum G-Code Programing
    Last Post: 06-20-2006, 11:24 AM
  5. Milling: low depth passes or all the width?
    By PEU in forum DIY CNC Router Table Machines
    Last Post: 11-03-2005, 12:57 AM
