603,970 active members*
2,163 visitors online*
IndustryArena Forum > CAM Software > Mastercam > help to customize my mcx2 post
    Jan 2008
    9
    hi i would like to know what to modify in my post to make it output the sequence number to match the tool # of my custom tool library
    here is an example of the format that i want
    T20
    N2700(SR32 FACE MILL) (WERE 00 IS THE SEQUENCE AND 27 IS THE TOOL #)
    (ROUGH PIPE)
    G0G90G55B0.S795M3
    G00X-8.225Y13.55
    G43H27D0Z3.5 (TOOL #)
    G1Z3.365F24.
    M98P257L25
    G0G90Z10.
    N2701(SR32 FACE MILL)(WERE 01 IS THE SEQUENCE AND 27 IS THE TOOL #)
    (ROUGH PIPE)
    G0G90G55B180.S795M3
    G00X-8.225Y13.55
    G1Z3.365F24.
    M98P257L25
    G0G90Z10.
    M98P5
    T4
    N2000(O3 CHAMFER)
    (CHAMFER ARROUD PIPE HOLE)
    G0G90G55B0.S2000M3
    X-5.4063.Y10.85
    G43H20D0Z15.
    Z3.49
    G1Z3.233F20.
    Y10.25
    G3X5.4063R5.4063
    G1Y10.85
    X5.25
    Y10.25
    G2X-5.25R5.25
    G1Y10.85
    G0Z15.
    M01
    M98P5
    thanks for the help
    Jul 2008
    139
    Look in your mcx folder. The documentation folder should have McamX2_Post_Parameter_Ref.pdf - This covers the topic on page 21. If you need help with implementing tool parameter calls in your post I would suggest the Emastercam forum for some help on actually coding the changes. There are some really good minds over there, especially on that topic. MP post script language that is. The V9.1 post ref is an invaluable tool for making post mods as well. If you don't have it you should get it from your local MC dealer.
  1. MCX2 Comp3D C-Hook
    By darkmet in forum Post Processors for MC
    Last Post: 08-05-2008, 03:49 PM
  2. MC9 to MCX2
    By Mitsui Seiki in forum Mastercam
    Last Post: 05-17-2008, 05:25 AM
  3. Customize Feedrate and 4 axis video
    By camtd in forum FeatureCAM CAD/CAM
    Last Post: 01-24-2008, 12:30 PM
  4. iTNC530 4th axis post for MCX2
    By Vicros in forum Post Processors for MC
    Last Post: 07-30-2007, 03:51 PM
  5. Help needed to customize output of Mach3
    By frenzal in forum Screen Layouts, Post Processors & Misc
    Last Post: 10-16-2006, 02:25 AM
