587,777 active members*
2,867 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Help with Double lead Thread
Hybrid View
    Mar 2011
    4
    Can I cut a double lead 2-56 UNC 2b thread with a thread mill
    Jun 2015
    4160
    Re: Help with Double lead Thread
    yep, should be possible ! you need a helix soubroutine, that begins at a random angle, or shift Z kindly !
    ps : if you use a custom toolpath, that reduces tool stress when entering the material, than you will have to rotate also this type of operation
    Jun 2015
    4160
    another way 2 do it is by using a temporary coordinate system : declare the program origin in the center of the bore and apply a rotation of 180 degrees ☺
  1. Double lead thread tooling
    By Barbara Edgar in forum Uncategorised MetalWorking Machines
    Last Post: 09-22-2011, 03:30 AM
  2. 1"-10 double lead thread
    By Busch Brothers in forum MetalWork Discussion
    Last Post: 07-10-2009, 08:38 PM
  3. Threading double lead acme
    By bmwfund in forum Diemaking / Diecutting
    Last Post: 06-04-2009, 11:26 PM
  4. double lead thread
    By johnmckeown in forum Haas Lathes
    Last Post: 12-04-2007, 04:49 PM
  5. how to cut a double lead thread on an engine lathe
    By Granary in forum MetalWork Discussion
    Last Post: 02-08-2006, 09:14 PM
