587,174 active members*
3,977 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > HELP!!! DYNA MYTE DM4800C VMC
Results 1 to 19 of 19
    Aug 2016
    13
    Question HELP!!! DYNA MYTE DM4800C VMC
    HALLO! I'm new here in the forum and i write this thread for find some help and info about a DYNA MYTE DM4800C MACHINING CENTER, these are the specifications:
    X AXIS.......................: 32"
    Y AXIS.......................: 20"
    Z AXIS.......................: 20"
    TABLE SIZE...................: 47.5" X 25"
    MAXIMUM TABLE LOAD...........: 1,100 LBS
    SPINDLE DRIVE................: 12 HP CONTINUOUS/ 15 HP 30 MINUTE
    RATING
    SPINDLE TAPER................: #40
    TOOL CHANGER.................: 24 POSITION BI-DIRECTIONAL
    RAPID TRAVERSE RATE..........: X, Y AND Z 472"/MINUTE
    SPINDLE SPEEDS...............: 60 - 6,000 RPM
    MACHINE WEIGHT...............: 11,440 LBS
    COMPLETE WITH:
    MITSUBISHI MELDAS CNC CONTROLS
    RIGID TAPPING
    FULL CHIP ENCLOSURE
    HARDENED AND GROUND BOX WAYS - ALL AXES
    STAINLESS STEEL TELESCOPING WAY COVERS ON X AND Y AXIS
    COOLANT PUMP AND SYSTEM
    ALL NECESSARY MOTORS AND CONTROLS
    The problem is that I don't have any manual about it and the machine is very old that I haven't found anything in Internet. Please, somebody help me D:
    May 2016
    7
    Re: HELP!!! DYNA MYTE DM4800C VMC
    We have a DM3300 that we are in the process of upgrading to a Mach3 control system. We have all the Manuals. They include: Mitsubishi CNC Meldas L3 Programming Manual, Maintenance Manual, Instruction Manual, AC Servo MR-S10 Maintenance Manual, and schematics of the machine. We could put them up for sale on eBay if you are interested.
    Rich
    Aug 2016
    13
    Thank you xibitology How much will they cost?, but first I would like to check if they have the information that i need, for example i have Meldas 500, Is equivalent to Meldas L3? or they describes the conection between Servos and controller in my DM4800C. Because I want to retrofit the machine.
    May 2016
    7
    I'll check tomorrow to see whether Meldas 500 is the same as L3.
    I yanked everything in the control cabinet but the Freqrol inverter
    and that is probably going too. It's just too old. The Mitsubishi
    Meldas system seems to be a dead end branch in the evolution
    of CNC.
    Upgrading the motion control is easy. It is the tool changer that's
    a challenge. It's not as critical with a lathe. At least for what we
    plan on using it for.
    What are you thinking to upgrade with.
    Mach3, Centroid, servo, stepper.
    Rich
    May 2016
    7
    I can't tell what the relationship is between L3 and 500.
    I do have a manual for Meldas AC servo MR-S10 Series
    that may be useful.
    It has pinouts for the encoders.
    Rich
    Jul 2009
    219
    Hi ROAD75,
    I replied over on the mach3 site.
    Why do you want to retrofit this machine? Is it not working?
    He He if you think that machine is very old, Then my 1983 Hardinge must be ancient! That machine is somewhere around 1995 and looks to be in decent shape.
    Personally, I would repair the existing Mitsubishi Industrial control and make money/ parts with it.
    I recommend using a Fanuc 0iMD control.
    Aug 2016
    13
    Quote Originally Posted by xibitology View Post
    Thank you Rich, for your time.
    I think is OK, I don´t have problems with upgrade the machine or using Mach3. For now, i need to replace the MELDAS and search about different brands of controllers advantege, disadvantage and Cost.
    Aug 2016
    13
    Talking Re: HELP!!! DYNA MYTE DM4800C VMC
    Quote Originally Posted by A1CNC View Post
    Hi ROAD75,
    Ja ja hello again A1CNC,
    Yes my machine didn't work u.u
    Well the detail it's that I think the MELDAS is damage and my boss suggested me replace all of it with a new cheap version of controllers. I'd rather have a comparison chart between brands about specifcations and costs, for do a report and then my boss can choose which is the best... BUT... if you have advices about how i can fixed it with any kind of manual or where to begin, I'm all ears
    Aug 2016
    13
    Quote Originally Posted by drdos View Post
    Hi, drdos thank you for reply. Why do you recomend it?
    Jul 2009
    219
    Hi Road75,
    I may be able to help. I had to do some repairs on my machine that has the Meldas 520. Lets start with what the machine does and does not do.
    I did notice the mitsubishi site is hard to find anything on now. It used to be much easier to find ALL the info on the 520 like troubleshooting and such.
    Aug 2016
    13
    Question Re: HELP!!! DYNA MYTE DM4800C VMC
    Well, this is what i have found for now, about MELDAS serie 500
    Mitsubishi CNC MELDAS 500M Series Instruction Manual - CNC Manual
    Mitsubishi CNC MELDAS 500 Series Maintenance Manual Hardware - CNC Manual
    And about... the machine the last I knew was that the controllers were on but the CNC didn't response with any comand. Please tell me which tests can be performed to find the root cause or about what i need to search.
    Jul 2009
    219
    Ok on page 14 of the maintenance manual you posted is a good place to start checking the trouble with the machine. There will be some indication of what is wrong.
    It could be as simple as a fuse. I had a wire break on one of the limit switches and the machine wouldn't move until I fixed it.
    I would print those manuals if you don't have a copy of them.
    Aug 2016
    13
    Ok thank you A1,
    Let me try it but i don't think is something as easy as change a fuse or fix a wire because other people with more experience try to fixed it.
    But i'll do and then relpy you what happend
    Also better clarify once and for all that... mmm i don't know the word in english but I'm like a student or a trainee in the factory and this is the first time that i have a project out of the Univesity.
    Aug 2016
    13
    Hi again A1CNC
    I was working in the machine and when I swithc on the machine the lights or the servos and controller turn on but CRT display doesn't.
    I checked that the CRT is powered and if it has any broken wired and i find all right
    Attachment 335290
    Attachment 335292
    Jul 2009
    219
    Hi Road75,
    There is a fuse on the CRT display. It is just above the plug labeled AC. You will see a round black fuse holder. Check that 1st.
    Do you have a voltmeter and know how to use it? If so unplug the AC plug and test to see that there is AC voltage at that plug after you press the power on green button on the front panel.
    I believe the english word you mentioned before is Intern.
  17. #17
    Aug 2016
    13
    Sorry i wrote that messages in my phone and I had some difficulties.
    Hehe, I forgot to mention that also I had already tested the fuse and the voltage in the AC plug. Here is a picture when the front panel is already on, but the display
    Another thing, I see that the plug J3 has a resistor conected, Is this ok? or What should be here?
    Thank you again A1CNC
  18. #18
    Jul 2009
    219
    Just looked at mine,
    There is a resistor there on mine as well. Also on mine, I can check the voltage with the plug still connected because the terminals are exposed enough to touch the meter leads to the terminals.Attachment 335484
    If you have voltage there but still no Image, you will need to have the monitor repaired/ replaced before you can get any further.
  19. #19
    Aug 2016
    13
    Ok thanks i solved that problem was just was a bad wired jeje
    Right now the panel show me this:
  1. DYNA MYTE DM4800C VMC MITSUBISHI MELDAS CONTROLLER
    By ROAD75 in forum Cincinnati CNC
    Last Post: 08-31-2016, 05:57 PM
  2. Dyna Myte DM5400?
    By Galane in forum Dyna Mechtronics
    Last Post: 02-14-2015, 08:46 AM
  3. Replies: 195
    Last Post: 03-02-2014, 02:17 AM
  4. DYNA MYTE 3000
    By SUE143 in forum Dyna Mechtronics
    Last Post: 04-09-2012, 06:00 PM
  5. DYNA MECHTRONICS DYNA MYTE 3000 AND 2800 WANTED!!!
    By britcollector in forum Want To Buy...Need help!
    Last Post: 02-23-2010, 04:20 AM
