603,960 active members*
3,794 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Help: each depth of the pocket I'm milling is offset from each other!
Results 1 to 6 of 6
    May 2012
    I'm running a ViperXZ with a PC 890 & Super P.I.D.
    I'm cutting a simple part out of MDF with a pocket around .6 deep. The problem: every depth I cut the pocket at seems to have "shifted" by about .2!
    So it looks like the pocket has steps on one side and fine on the other.
    Has anyone encountered anything like this? I'm programming my paths in X4 and controlling my machine with Mach3.
    Thanks!
    Feb 2004
    305
    Sounds like your spindle is not square. Have you ever trammed it? Did you mean shifted .02" or .002", not .2"? If .2 you much have another problem.
    May 2012
    That's the thing, my spindle is square and the shift is 0.2! Looks like something else altogether... I'm really scratching my head over this one. I'm going to try cutting the same pocket today and see what happens.
    Mar 2003
    35494
    Do you mean the X or Y axis have shifted? If so, I'd remove the motors and turn the screws by hand to check for binding anywhere. If there's no binding, reduce the acceleration by 10-15% and see if it helps.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2012
    Gerry you're a life saver! It was the X that had shifted. Checked for binding and found none so I reduced acceleration by 10% and I'm back in business!!
    May 2012
    Update: it wasn't the acceleration after all but that helped me diagnose the problem. I'm such a wanker! It was a loose coupling. Easing off the acceleration took some stress off the stepper so it looked like everything was fine. When I put in a bigger end mill the problem came back. All sorted now.
    Thank again
  1. Advance Pocket or Offset Pocket
    By aldepoalo in forum BobCad-Cam
    Last Post: 01-31-2013, 07:46 AM
  2. Replies: 1
    Last Post: 11-30-2011, 07:51 PM
  3. Pocket depth
    By paszo in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-05-2011, 03:01 PM
  4. Pocket island depth
    By paulpounds in forum Mastercam
    Last Post: 03-25-2009, 10:34 AM
  5. Depth of Pocket for Letters
    By whiteriver in forum Composites, Exotic Metals etc
    Last Post: 10-15-2004, 08:24 PM
