Hello from Australia. We are suffering from our 5th day with 44c temperatures.
I own a 1997 4020. I have turned the machine on this afternoon, started the spindle and tripped the emergency stop. The controller has displayed "c axis, fault 9, spindle fault line". When I turned it back on with spindle on 10% rpm it ran ok and sounded fine but the spindle load was high at 30%, when I slowly ramped it up to 100% the spindle still showed 30% load. If I ramped the spindle up quickly it seemed to hesitate then speed up several times before reaching 100%, it did this fairly slowly and the motor would shudder when it hesitated. Once the spindle had reach 100% rpm the load showed 100% and the emergency stop then tripped. Strangely the load meter would remain on 30% for several seconds after I turned the spindle off myself.
Could the excessive temperature we had today cause problems ?. The workshop is air conditioned but the machine was started before it was cool.
Any help would be great, as I run a small shop and this machine does all of my work.
Cheers Matt
