Originally Posted by
deanmachine
We are useing the proper tool identical to your pick
We are a little confused with this you say :
"btw don't use U positive when roughing a face shape otherwise your tool will cut into the finish profile on the rough passes.
If anything you want U- but U0 and W positive will work just fine for your profile."
Do you mean write my path from the center out? we tryed that and it just runs our fin path and did not step in we even
made our z 0 at the bottom of bore instead of face of part will not step ???
Many Thanks,
dmachine
