603,319 active members*
2,459 visitors online*
Page 2 of 2 12
Results 21 to 31 of 31
  1. #21
    Dec 2004
    24
    Lets see if this is what you want.
    It is metric but you will need a 1/8 router bit.
    Attached Files Attached Files
  2. #22
    Jul 2004
    83
    Thankyou Pythagoras, I will take a look at them this afternoon.
    You guys have been a really big help!!
    Thanks Again.
    Chas
  3. #23
    Jul 2004
    83
    Pythagoras, sorry for not getting back to you earlier.
    Thankyou once again for all your help, the second code
    was small enough to fit on my machine, however not
    sure what happened as it was removing the excess
    waste between the i and the l of phil the machine
    went crazy and started removing material from where
    the p and the h was. I didn't have enough time and
    I used the simple phil code that vlady sent as the
    sample to show the customer. Since then I have
    dissassembled the machine to finish the aluminum
    so machine looks pretty (haha) The sample was
    enough to show customer. When I reassemble the
    machine I will try the code again, I'm sure that it
    was something that I did that went wrong.
    Once again thankyou for all your help I really
    appreciate your time!!
    Chas
    P.S. what software are you using, and what would
    you suggest as beginer cad/cam??
  4. #24
    Feb 2004
    361
    If all you want for the near future is just something relatively easy to use, grab a copy of DeskEngrave, the price is right, and while it does have limits, it will let you USE your machine while you try and figure out which package is right for you, and within your budget..
    enjoy
  5. #25
    Jul 2004
    83
    Vladdy, I tried deskengrave I typed the work phil in and
    chose the output as gcode. All I ended up with is 2
    3d boxes. What did I do wrong??
    chas
  6. #26
    Sep 2004
    59
    what kind of code do you want? send me and email pic and I'd be glad to turn it into code for you. need more info what kind of controller what software ect..here is sample pic of a digital photo turned into art on hardwood 13 x 18 8 million lines of g code. and the 24 hr message is just g code for a simple sign for my wifes realestate business..
  7. #27
    Jul 2004
    83
    Thanks for your offer troyswood, I don't actually need any
    code right now, vladdy and pythagoras send me some code
    to show my machine in motion, I had tried deskengrave to
    create code for the word "phil" and ended up with 2 3d
    boxes, I was just asking if anyone knew what I did wrong??
    Now that I have a working machine, the next curve is
    learning cad/cam. I had assumed that deskengrave was
    a good starting point to create something.
    What software did you use to create the picture??
  8. #28
    Sep 2004
    59
    BobCAD/CAM
    Attached Thumbnails Attached Thumbnails s family pic cnc wood reduced for email.jpg
  9. #29
    Jul 2004
    83
    Bobcad/cam is one of the software packages I am looking at.
    Still looking at what each package has to offer and sit down
    and think of all of the things that I am going to make on the
    machine so I can make an educated decision.
    I will keep you in mind.
    Chas
  10. #30
    Feb 2004
    361
    Not sure what you did wrong.. you are on the steep part of the learning curve..
    anyways, I tried it here, typed in the text in the text box, selected a font and a larger size, and got the preview on the center box in the program..
    Only change from default was to select a depth of 0.05 in the parameters menu..
    saved as g-code, and ran through a simluator, and seemd to come out ok..
    secondly, I was looking at BobCad here last week, but other things cam up and funds are too tight. They had [probably still have] a deal on V19, at [not sure] 500 or 600 US... pretty cheap as it's no longer the current version. Best part is price to upgrade to 20, anytime, even next day, was I think 395 US..
    A rather large saving over just buying 20 a retail on their site..
    I talked to Nate there at BobCad if it matters..
  11. #31
    Feb 2005
    78
    G'day Chas
    Here is a G code for you. You will have to edit the start and end of the program as this is for a metal milling centre.
    Good luck
    OldJohn
Page 2 of 2 12
  1. Autocad to gcode
    By JamesMI in forum Autodesk
    Last Post: 12-02-2011, 09:54 AM
  2. Is it possible to get a gcode into Rhino
    By MrBean in forum Rhino 3D
    Last Post: 04-03-2005, 01:41 PM
  3. gcode to gcode converter
    By july_favre in forum Uncategorised CAM Discussion
    Last Post: 05-25-2004, 12:51 AM
  4. dxf to gcode problem...
    By freezer in forum Uncategorised CAM Discussion
    Last Post: 02-19-2004, 07:02 AM
  5. Gcode verify autocad plugin
    By balsaman in forum Uncategorised CAM Discussion
    Last Post: 10-31-2003, 06:22 PM
