help with gcodes
I am almost ready to move into full gcode programming and I am sure I will need some help. The only experience I have with gcodes is G00, G01, G02 and G03. That is all my machine was able to use. I have down loaded the beta of Mach2 which is limited to 1000 lines. Due to the limited nature of my gcode files I can't get any of them to run. Is it because there needs to be specific info in the first few lines i.e., absolute or incremental, toof offset, tool length comp, etc. As you can tell I have a lot of work to do but any help would be appreciated.
If some one has a sample hundred line file that I could run that would be appreciated and I could see how it is set up. TIA
turmite
No greater love can a man have than this, that he give his life for a friend.
