587,262 active members*
3,306 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > HELP HELP HELP. HOW DOES A MACH3 CNC know where XYZ Homes are?
Results 1 to 5 of 5
    Sep 2003
    1473
    Setting up mechanical switches for XY and Z.
    I want all three to be in their home positions when I REF ALL HOME, but how does the CNC know where their home is?
    There must be some place that you tell it, and where is that?
    Sounds simple, can someone tell me?
    Apr 2018
    137
    Re: HELP HELP HELP. HOW DOES A MACH3 CNC know where XYZ Homes are?
    One way is to use "home switches". See section: "4.5 Limit and Home Switches" in this PDF:
    https://www.machsupport.com/wp-conte...all_Config.pdf
    Jun 2005
    1730
    You typically put X home on the far left side of the axis. The Y axis is traditional all the way to the front of the machine. The Z axis is traditionally reversed meaning going home on Z is the farthest position above the table. You test each axis and ensure that axis starts moving in the direct of that axis home switch. If it moves in the wrong direction change config in Mach3 to reverse home direction.
    Mar 2008
    454
    I use one of these on both sides of each axis: (so you will need 6 for 3-axis)
    https://www.ebay.com/itm/272454184681?
    They are inductive proximity sensors that trip when roughly 4mm away from another piece of metal (no physical touch).
    with these in place, you can ref-all-home as long as you link each axis pair to a single input, so you will need to use 3x inputs (a pair for each axis).
    If you would rather a touch sensor:
    https://www.ebay.com/itm/160884893454?
    Work the same way but need physical contact
    For the Z-axis, Height is typically inconsistent depending on tool used... a touchplate will automate the task.
    https://www.ebay.com/itm/234282797882?
    Nov 2013
    4493
    Prior to mach being homed or reference it does not know where the switches are. In fact that's what they are for, when Mach does find them then it knows where the machine
    Home is....where the switches are.
    You can in fact put the switches anywhere you like. It does not matter whether a home switch is in the center of travel, or whether it at at the end or near to it. All that really matters
    is that it stays the same. I have my Home switches about 10mm 'inside' one of the limit switches.
    When you set up Mach homing it asks 'which direction should I go to find the home switch', you can answer 'go right' or 'go left'. If you had a home switch in the middle the machine might
    'go left' because that what it knows to do, but if the switch is already behind it, then Mach wont find a home switch BEFORE it bangs into a limit switch. That why I have my home switches
    very near the end, then if I say 'go left', the switch is almost certainly ahead not behind.
    Craig
  1. Odd CNCEST Mach3 Behaviour Either Movex XYZ or Spindle but not both
    By OiUkes in forum Machines running Mach Software
    Last Post: 12-11-2023, 12:19 PM
  2. Mach3 XYZ Axis Calibration
    By aliqamar in forum Calibration / Measurement
    Last Post: 02-29-2016, 09:19 AM
  3. Handcrafted Log homes with CNC
    By Duesentrieb in forum News Announcements
    Last Post: 12-17-2011, 07:17 PM
  4. XYZ TECHNOLOGIES LTD.(WWW.XYZ-TECH.COM)
    By EXLASer in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-02-2010, 10:37 AM
