603,365 active members*
4,020 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Help with identifiyng Southbend Magnaturn
Threaded View
    Sep 2006
    94
    Hello.
    We have a Southbend Magnaturn lathe. I believe it is a 1218 or a 1220, I do not know which. It has two floppies on the front and a hard drive inside. The hard drive is failing, fast.
    The serial number is 00151.
    This machine has seen very little use.
    I could use some specs on the thing; travels, spindle rpm, types of servos, etc...
    I could also use some recommendations for a possible retrofit.
    Thanks,
    Heath
    Attached Thumbnails Attached Thumbnails Southbend - Bridgeport CNC Lathe 001.jpg   Southbend - Bridgeport CNC Lathe 004.jpg
  1. southbend magnaturn 612
    By cidteach in forum Mini Lathe
    Last Post: 01-15-2011, 11:13 PM
  2. Southbend Repair or 10x22
    By 2_many_hobbies in forum Mini Lathe
    Last Post: 01-03-2010, 07:22 AM
  3. Southbend Lathes
    By cmnewcomer in forum Uncategorised MetalWorking Machines
    Last Post: 07-18-2009, 09:53 AM
  4. Southbend 9" dial thread indicator
    By BillTodd in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 08-31-2008, 08:45 PM
  5. MagnaTurn 612
    By dustydragon in forum Uncategorised MetalWorking Machines
    Last Post: 10-10-2007, 02:37 AM
