587,256 active members*
2,822 visitors online*
Results 1 to 4 of 4
    Feb 2006
    15
    Help identifying servo
    Hi everyone,
    A friend of mine came across what appears to be some sort of servo motor, and we are having trouble identifying it. Any help anyone could give would be appreciated, here is what we have so far:
    Motor specs:
    Torque Systems Incorporated
    An EG&G Rotron Co.
    Waltham, MA USA
    Model No. MT-2015-017U4G10
    Dual motor shafts, 1/4" dia.
    Motor diameter: 2.02"
    Motor case length: 5 3/4"
    Windings are 0.014" diameter copper
    The motor is labeled "PM Field DC Servo Motor" and has one of those ancient DC generators as a speed output (pretty much a 2nd brushed motor going along for the ride). I ran the motor at various voltages, measured the rpm with an external tachometer, and measured the voltage from the generator. I've never played with one of these before, and I was (literally) shocked at the results. At 45.8 VDC to the motor (the highest the DC power supply I'm using can go), the motor hit 7414 rpm, and the output of the DC generator was 102 Volts! Yowza! (Here I was expecting something like 5-12V.)
    Anyone familiar with this era of technology have an idea of what this motor is supposed to be running at? At no load I measure the following:
    3773 rpm @ 24.0 V, ~0.28 A, Vgenerator = 52.5 V
    5767 rpm @ 36.0 V, ~0.30 A, Vgenerator = 79.4 V
    7414 rpm @ 45.8V, ~0.30 A, Vgenerator = 102.4 V
    At stall, it pulls about 3.5 A @ 24 V. (I wimped out on higher voltages.)
    Any help anyone can give us, I would appreciate it!
    Dec 2003
    24223
    These motors are the same as the CMC models, you should be able to find it here, they have been a work horse motor for many years .
    http://www.cmccontrols.com/servo_motors_downloads.asp
    http://www.cmccontrols.com/downloads...duct_Guide.pdf
    The 'DC generator' is a DC tach that was previously used on velocity drives, they are not generally used now with Torque mode drives.
    I am pretty sure you have exceeded the maximum RPM that these motors are rated at, I think the highest rpm model was 6krpm.
    Al.
    Albert E.
    Mar 2007
    137
    Al is the man! I have seen a lot of servo motors, and i don't remember any going over 4,000 rpm.
    Dec 2008
    17
    Hi dear friends.
    I need the data sheet for this servo motor. I took this info from the nameplate:
    PM FIELD DC
    SERVO MOTOR
    EG&G
    TORQUE SYSTEMS
    MODEL NO:ME4257 118E
    CODE 0916
    SERIAL NO 692662
    I can not find any info on the web.
    Any help .
    Thanks.
  1. Need help identifying
    By pflynnjr in forum Stepper Motors / Drives
    Last Post: 04-18-2007, 05:58 PM
  2. Identifying SEM servo motor torque
    By boringmill in forum Servo Motors / Drives
    Last Post: 12-27-2006, 05:22 AM
  3. Help identifying tools
    By ecbntmkr in forum Community Club House
    Last Post: 07-12-2006, 02:59 PM
  4. Help identifying servo motor
    By Corvus corax in forum Servo Motors / Drives
    Last Post: 10-26-2005, 03:34 AM
  5. Help identifying this please
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 12-05-2004, 08:40 PM
