587,283 active members*
4,832 visitors online*
Results 1 to 8 of 8
    Apr 2010
    Red face help-ie300(iehk) laser engraver
    just answer please.. it is posible to drive engraver with laptop??
    i have usb-adapter..(trednet). lpt. ..but its seams that is not working .
    yes or no..
    or i must by desktop comp
    thanx
    Sep 2008
    117
    Quote Originally Posted by srle76 View Post
    Yes, the laptop should do it fine. You should install the driver software to the laptop BEFORE plugging in the laser. If you have not installed the software first, then Windows will assign the best driver it thinks it should use and it will not be right.
    You will probably need to uninstall that USB and then install the software and finally plug the laser in.
    BE CAREFUL WHAT YOU REMOVE IN THE FOLLOWING INSTRUCTIONS
    To uninstall the USB controller go to
    Start
    Control Panel
    Device Manager
    Universal Serial Bus controllers
    Find the controller and remove it.
    To uninstall the USB port assigned to it
    Start
    Control Panel
    Printers
    Select the printer driver for the laser and right-click.
    Click the "Ports" tab and look down the list for...
    USB: < whatever the laser is called >
    Remove it.
    Reboot and then load the software and after that plug the USB in.
    Please make sure you know and understand what you are doing when removing stuff.
    Dave
    Apr 2010
    thanx
    yessss :rainfro::rainfro::rainfro:
    thanx for your time
    Dec 2008
    1258
    Were you successful?
    I would be surprised if this worked since the iehk300 uses direct parallel handshaking which is likely not supported with a USB-->Parallel adapter.
    Zax.
    Apr 2010
    not working
    nothing ...uhh...must fix some old computer
    Dec 2008
    1258
    not working
    Sorry to hear that, but not unexpected.
    Some of the parallel port units will work with a USB adapter, providing they use a standard Windows driver. In which case Dave's step by step guide will do the trick.
    Zax.
    Oct 2011
    driver choice?
    So what driver would you choose for the IE300 then?
    cheers
    Jake
    Oct 2010
    I've never had good success with hooking up anything other than a printer up to a USB/parallel adapter. Sorry. You may be better off looking for a PCMCIA parallel card for your laptop. That is assuming you have a PCMCIA slot in your laptop. You can pick them up on ebay for about $15 including shipping.
  1. wklaser(Gweike laser) new laser engraver display
    By tina in forum News Announcements
    Last Post: 09-22-2011, 12:20 AM
  2. CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!!
    By oliver9866 in forum Engraving Machines
    Last Post: 12-15-2010, 09:44 PM
  3. Instructions for IE300 series Laser
    By McDuck in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-15-2008, 07:22 AM
  4. Why buy a Laser cutter when you can modify a laser engraver.
    By spacifique1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-13-2007, 08:39 PM
  5. Need Help With IE300 Laser Engraver
    By JWiggers in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-03-2007, 03:56 PM
