587,415 active members*
3,368 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Help with lead screw & motor - 1st build near done
Page 1 of 6 123
Results 1 to 20 of 106
    Mar 2008
    454
    Question Help with lead screw & motor - 1st build near done
    Hello,
    I have been slowly gathering parts for my first CNC build and need a little help determining a good lead-screw & motors for my needs.
    I already have rails, bearings & complete Z-axis, frame will be made entirely of 8020 t-slot. X rails = 4' & Y rails = 2', max travel has not been determined yet but I am not too worried about having as much as i can get... my parts to be cnc'd will be small. applications are PCB & small aluminum cases, need to be as precise as possible, the aluminum cases will hold optics and have very small tolerances.
    I have gone through alot of threads and am not too much clearer on determining a proper motor & lead-screw combo. I am not pinching pennies, so I would rather spend a little extra to do it right the first time.
    Can someone recommend a good ball-screw & backlash nut with proper pitch, & a set of motors to match?
    I dont mind reading and learning myself, but everything I have come across is specific to the authors needs... which primarily seems to be wood, and of course different lengths.
    Any help is greatly appreciated
    p.s. - I do have a nook catalog but its mostly greek to me :/
    Mar 2008
    454
    My design is near identical to this one, however I have decided to put the X rails below the table.
    That means the X axis lead-screw, and the X axis rails will be on the same plane.
    Apr 2008
    3
    Have you looked at www.pdjinc.com ?
    Mar 2003
    35538
    How fast do you want to cut and rapid at? And what are the tolerances you're looking to hold?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2008
    454
    wow thanks for the fast reply's!
    I'm not really clear as to those ger... i dont know how to translate the cut/rapid to an actual work time.
    I have seen other PCB makers go for with tolerences of .01 i believe?
    that will also suit my aluminum case needs.
    Im more concerned with accuracy than speed, however i also dont want to wait 24 hours for a 3" square box to be completed
    Mar 2003
    35538
    .01", or mm? if inches, anything will do that. Most people building Joe's 4x4 machines are using 1/2-10 5 start acme, and DumpsterCNC AB nuts. much cheaper than Ballscrews, and will still give good performance. As for motors, it really depends on how much you want to spend, and how much force you need. A keling G540 package will work.
    http://www.kelinginc.net/CNCNEMA23G540Package.html
    If you want more speed and power, I'd go with Nema 34 motors and Gecko G203V's. 400-600 oz motors, rated around 6 amp will get you the highest speeds.
    Gerry
    Mar 2008
    454
    That's one thing in not sure on is how much force it sill take to cut soft aluminum... I know pcb's take near nothing.
    I looked at the G540, but looks like it will come with 2 more motors than i need since i already have a Z axis completed. Maybe im understanding it wrong but it says 4-axis, so im assuming 4 motors?
    any location i can read more about those leas screws?
    Thank you for your help
    also, i took a look on my micrometer and .005 or less would be preferred
    Mar 2008
    454
    ooh ger, I just read a post from you in another thread about making sure to have 'home' switches. I realized i completely forgot about that, are those supposed to connect to the drivers? or are they just an emergency crash switch that cuts motor power?
    I am using the allegro bi-polar chopper from pminmo.com
    http://pminmo.com/ss3977/ss3977.htm
    Mar 2003
    35538
    You already have the drives for all the axis?
    Gerry
    Apr 2007
    8082
    Quote Originally Posted by viroy View Post
    The G540 has four individual stepper motor driver boards in one assembly. It can drive up to four motors, but you can just use three and not use the fourth driver, or use the fourth driver on a dual motor X axis machine. You can also use the fourth driver for a rotary axis if you wish to. It has lots of possibilities.
    If you buy it from Gecko Drives it comes with no motors. They only sell the driver modules. If you buy it from another source that sells the G540 you have the option to buy a 3 or four motor bundle.
    Home switches allow the software to run the motors to a known position that is detected when the three switches open as the motors reach that predetermined position. Home switches can be set up in software as home and limit switches in combination. Limit switches tell the software to stop the motors before running into the end of mechanical travel and potentially causing damage.
    There are software limits also, and are set to define a "box" that will define how far the motors can go. This can be the only limits, or it can be used in addition to the limit switches as two levels of avoiding damage.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Jan 2005
    37
    G540 on sale
    I just ordered the G540 directly from http://www.geckodrive.com/for $210.00 (They are currently having their customer appreciation sale). You could order 2 motors from http://kelinginc.net/ for $39 or $49 each which would give you a very nice package for about $300. The G540 also includes connections for limit switches as well as outputs for relays.
    Incidently, I received my G540 (in Canada) about 26 hours after I placed the order. I was impressed!!!
    Ayjay
    Feb 2009
    499
    You won't go wrong with the g540's. I am very impressed with them and the company service. You can see my build log for more about the 540's at www.liming.org/cnc
    I just wish they were that cheap when I bought them!
    Mar 2008
    454
    Wow they have some incredibly strong motors there.
    I have been taking autocad classes and am somewhat comfortable with it now... I have 8020's autoquoterx add-on working and half of the frame designed. I'm now to where I need to design the lead-screw mounts and the motor mounts.
    So I think I should go ahead and purchase lead screws and motors.
    As I said before, I have a complete z-axis already done... I bought a pre-built kit that has 4" of travel. see attached picture
    Apr 2003
    312
    That looks like a Paul Jones Instant Z Axis.
    Senna
    Mar 2008
    454
    Mar 2008
    454
    Ok im ready to purchase a lead screw for the x and y axis...
    but im a little insecure about purchasing something I dont fully understand.
    The x axis is 48" long, so im worried about thickness to prevent swaying/sagging.
    I did some reading and it seems the more starts the better, and roller screws have gotten better precision ratings than roller balls.
    What im thinking is something like 5/8-?-4
    Im planning to direct drive the lead screws, so how do i figure out IPM?
    Precision is more important than speed to me.
  17. #17
    Mar 2008
    454
    hmm 5/8 is just over 1/2"... maybe I should go thicker to 1"? ...something like 3/4-?-5, or 1"-?-6. Are all lead screws perfectly balanced for rotational force?
    I dont understand how to determine the amount of threads per inch I should go with.
    I happen to read that polished stainless last much longer than coated, due to the coating material flaking off over time?
    In these forums I read about a very neat way to avoid racking with a "moving knot".
    Seems very practical and quite easy... would this be recommended for me since I will be using a single, centered X-axis lead screw?
    Sorry for all the noob Q's
    I really appreciate the help
  18. #18
    Aug 2008
    1166
    If the x is 4' and the y is only 2', you might not have too many problems with racking. Leave room for the cable setup in case you need it, but I'd try without first.
    I have a 48" long axis with a 1/2-10 5 start screw that works fine. I run it up to 200ipm, but it could probably go a bit faster - 300ipm max. Above that the screw whips. So if that's fast enough for you, I wouldn't get a bigger screw. If you want to go faster, check out the critical speed charts that Nook has on their site to get an idea how fast you can spin a screw before it whips (called the critical speed).
    Picking a lead screw depends on how fast you want to go, what resolution you want, how much force you want, and what motors you have. Here's a thread with some helpful links for figuring this stuff out - especially the cnc mechanics pdf.
  19. #19
    Mar 2008
    454
    Cool i didnt know that (critical speed)... helps alot.
    Can you post that link? It didnt go on the last post
  20. #20
    Mar 2008
    454
    I dont know how 200ipm will look while cutting, but I will be doing very tiny grooves for optic mounting... and I'll only be needing a few at a time so im not planning to run this full time mass production.
    I found this for nooks critical speed chart... i though it would be easier to read as I cannot find anything comprehendable. looks like "INCH SRT, XPR AND SGT CRITICAL SPEED" is the relevant chart... but what do the numbers on the right side denote? are those product num's?
    http://www.nookindustries.com/ball/ballcharts.cfm
Page 1 of 6 123
  1. Problems with motor stalling due to motor/lead screw alignment
    By Bimmerkc1 in forum DIY CNC Router Table Machines
    Last Post: 01-25-2010, 01:12 AM
  2. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  3. Making a coupler between motor and lead screw
    By nikolatesla20 in forum Mechanical Calculations/Engineering Design
    Last Post: 07-30-2005, 07:05 PM
  4. Problems aligning motor with lead screw.
    By SCCoupe in forum DIY CNC Router Table Machines
    Last Post: 02-16-2005, 01:33 AM
  5. coupling motor to lead screw ideas?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 09-15-2003, 05:18 PM
