587,960 active members*
3,693 visitors online*
IndustryArena Forum > MetalWorking Machines > Colchester Tornado lathes > HELP LOOKING FOR SOLUTION TO MATCH UP C AXIS TORNADO 220M
    Mar 2009
    5
    HI PEEPS LOOKING FOR SOME HELP WITH A MACHINING PROBLEM .MACHINING 800MM LONG TUBE C AXIS DRILLING TO BE REPLICATED ON OTHER END OF TUBE CAN ONLY HAVE 400 MM OUT OF CHUCK SO WHEN I TAKE TUBE OUT TO TURN AROUND HOW DO I GET MY C AXIS HOLES TO MATCH UP IDENTICALLY ON BOTH SIDES ANY HELP WOULD BE APPRECIATED
    Apr 2006
    3206
    You need some kind of indexing feature on the part, and a mating feature on your workholding. Barring that, you need some kind of fixturing that will clamp down on the part and allow it to be flipped and the fixture indexed to a master jaw, chuck, collet, whatever.
    Mar 2009
    5
    THANKS I TRIED TO LINE UP MY FIRST C0 HOLE WITH DRILL BUT WHEN I START PROGRAM IT CHANGES MY C0 POSITION DRILLING AND TAPPING 10 HOLES AT 36 DEG ALONG TUBE LENGTH .IS IT BECAUSE MY PROGRAM IS USING G28C0 AT START ??
  1. Colchester Tornado 220M
    By Turnalot in forum Colchester Tornado lathes
    Last Post: 07-23-2015, 09:18 PM
  2. 4th axis Mis-match
    By prdp141 in forum Rhinocam
    Last Post: 06-11-2013, 05:02 AM
  3. Axis travel (physically measured) doesn't match Mach3
    By neeboy in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2012, 12:36 AM
  4. adding 4th axis: need to match existing servo?
    By BiggerHammer in forum CNC Machine Related Electronics
    Last Post: 01-14-2010, 01:35 AM
