Milling some pockets out of oak on a CNC router. Setup using mach3, it leaves one corner radius of the pocket exactly what it is supposed to be (12mm diameter cutter used). The other 3 corners are not correct.
I have tried multiple software and eliminated that, I have also tried 2 different machines and eliminated anything mechanical. tried foam thinking it may be the oak that is the issue, have also decreased the acceleration, slowed the speed, and tried larger size rectangles but it always leaves the corners incorrect. very strange!
A pic is attached to show what I mean. Code is also shown below, its very simple code.
Any help would be much appreciated. It hasnt been noticed up until now however inlays just wont fit correctly.
I must also say that the start and end points of the rectangular pocket are perfect and that it cuts perfect circles.
G90G17
T1 M06
S500
F3000
M03
G00 X18.686 Y14.462 Z20.000
G00 X18.686 Y14.462 Z0.000
F500
G01 X18.686 Y14.462 Z0.000
G01 X8.686 Y14.462 Z-3.000
F2000
G01 X76.686 Y14.462 Z-3.000
G01 X76.686 Y17.000 Z-3.000
G01 X76.685 Y17.061 Z-3.000
G01 X76.624 Y17.062 Z-3.000
G01 X8.748 Y17.062 Z-3.000
G01 X8.687 Y17.061 Z-3.000
G01 X8.686 Y17.000 Z-3.000
G01 X8.686 Y9.124 Z-3.000
G01 X8.687 Y9.063 Z-3.000
G01 X8.748 Y9.062 Z-3.000
G01 X76.624 Y9.062 Z-3.000
G01 X76.685 Y9.063 Z-3.000
G01 X76.686 Y9.124 Z-3.000
F3000
G00 X76.686 Y14.462 Z20.000
F500
G01 X18.686 Y14.462 Z-3.000
G01 X8.686 Y14.462 Z-6.000
F2000
G01 X76.686 Y14.462 Z-6.000
G01 X76.686 Y17.000 Z-6.000
G01 X76.685 Y17.061 Z-6.000
G01 X76.624 Y17.062 Z-6.000
G01 X8.748 Y17.062 Z-6.000
G01 X8.687 Y17.061 Z-6.000
G01 X8.686 Y17.000 Z-6.000
G01 X8.686 Y9.124 Z-6.000
G01 X8.687 Y9.063 Z-6.000
G01 X8.748 Y9.062 Z-6.000
G01 X76.624 Y9.062 Z-6.000
G01 X76.685 Y9.063 Z-6.000
G01 X76.686 Y9.124 Z-6.000
F3000
M05
M02
