When making replacement gears I need to measure the old gears as accurate as possible.
I also wanted to use a gauge for tool grinding purposes for rack gear and internal gear.
Metal gear gauges are expensive, only have modules up to 3 or 5, often curved blades and with only one contact angle value.
So when a colleague asked me to design a all-in-one solution I finally made my gauge but need help with this.
- Does someone know if "metric" gear will mesh with "Thread per inch" gear?
- To cut the gauge blades I lasered plastic sheets but in small corners burns away to much resulting in inaccuracy.
To make and try the prototype I used scissors, never gonna do that again in this lifetime!
I tried CNC-knife cutting but get's stuck in narrow corners. Apparently the knife also needs a stepper to turn to the cutting direction.
Any idea how to accomplish that?
This is a video of my universal gear gauge untill now.
