I have 3 stepper motors. (2) 640 oz @ 2.3 volts/5.5 amps and (1) 270oz
@3.75 volt/2.8 amps.
I think I bought to big. I bought a 800V 60V + 60 V toroidal.
Any help would be appreicated.
My capacitor is a 37,000 uf
You can never be too big.....we've done these calculations at least a thousand times on this web site....do some searching.....we can then clarify any confusion....
I did some searching and not sure I got anything out of it. Found one person using same set up (Gecko 202 and 640 oz motors) but was using a 48VAC transformer. Another guy had a 100VAC transformer.
I'm stupid but learning this Greek. All I want to know is if I hook this 60 V + 60 V/ 800VA up and use a 25 amp rectifier and have a capacitor (37,000 uf)with a 75V surge rating will it be enough and not kill my motors and blow up my single capacitor.
I guess in the long run the motors will only draw what they want if the supply is there. Right?
If you want to reduce the secondary voltage, there are plenty of posts here describing it, it is relatively easy with a toroidal transformer.
Al.
Albert E.
Thanks, but I don't know if I'm too big or just right? One response was that I couldn't get too big. Is that right? If so, maybe I'm okay.
Okay...look at this. say my 60VAC is what I need or about and I need to convert to DC. I suppose with the right rectifier I will come out with 60VDC or about.
That rectifier, should it be a minimum 60V or can it be a 50V to do the job. I don't see a 60V anywhere is why I ask. 25 amps is what the desired amperage should be. So when ordering what should I look for. I know now I probably ordered the wrong one.
Thanks.
The rule of thumb I was given was that voltage should be 4 to 20 times the rated voltage of the motor. I forget the rule of thumb gfor amperage.
I think I'm going to send my transformer back and get a smaller one. I just read where one guy needed about 57VDC and bought a 55VAC. When the he checked on the back side of his capacitor he was over 84 VDC, which was too much for a Gecko Drive.
I've got a 60VAC secondary so there is no question what I'll have too. More than him likely.
This has been a horrible experience. It's so clear to someone who is in the electrical circles but I'm not and having to dig for info is tough!
All I want to know is what I have work. I don't think so.
60vac after a rectifier will be ~85vdc ( Vdc=1.414*Vac). That's too high and why Al the Man was suggesting the secondary vac needs to be reduced.
I wouldn't run the 2.3 motors at more than ~48-55vdc, (20-25x plate voltage), 3.75 motor could be 75-90vdc but then drivers get expensive. For convenience you could run all three on the same voltage, the voltage is also governed by the capacity of your drivers..
48vdc needs ~34Vac into the rectifier. 55vdc needs ~39vac etc..
I'd suggest Amps would need to be ~11amps. For a transformer with ~11amps at ~39vac (55vdc) i'd get a transformer with secondaries of ~39vdc and at least 450va rating.
Capacitor needs to be rated at over the VDC voltage, uf rating depends upon the ripple you'll accept but the usuall rule is uF = (80000 * I) / V, so for 11a and 48vdc you get 18333uf at greater than 48vdc rating
Thank you, Thank you. finally an answer I can understand.
My 60V is packed and ready to go back. All I'be out is the freight.
So rectifier wise?? maybe a 50V /25 amp or something like that.
You do not need to size the rectifier close because there is very little difference in price between sizes, go with a 25amp 300~400 PIV.
50v is too low.
Al.
Albert E.
Got cha. Just ordered it from Parts Plus.
Thanks again. You've answered two weeks of questions in about 1 hour.
Gee! Great help.
Remember, it you have to much voltage coming through you can always cut it down with a zenner diode or two.
Steven
NOw that I got that done. What's the best way to attach driver to heat sink? I don't see any screw holes.
WEll i dont know what drivers you have, but its often the transistors that heat up.
But this is how you mount transistors to a heatsink. Get a piece of 1/8" aluminum, drill and tap holes.
