Hi MAG45
I guess the error message is either because a limit switch or its wiring is faulty
or more likely the printer port input has been damaged (the part connected to pin 10)
does the breakout board connect to the computer printer port or some other hardware ?
not using Linux I don't know how you use Linux to display the status of the input port
(I expect there is software you can use to test the pointer port if that's what you're system uses )
John
