587,214 active members*
3,508 visitors online*
Results 1 to 6 of 6
    Feb 2007
    126
    help me mr. wizard
    Hi all. I've been given a "problem" to figure out by my supervisor.
    I am running a Mori-Seiki SV-50, control FS-15M. There is a light on the top of the machine which shows green while the machine is in cycle. My manager noticed that the green light is sometimes on at other times.
    I experimented with it and found that using MDI mode would cause the green light to come on, and that it would stay on till given an M30, either from a program cycled or in MDI.
    He is adamant that this is a problem which needs to be fixed and I would like to satisfy him. Can anyone help me?
    Aug 2008
    53
    Cycle Start
    Hello,
    It appears as though the Pat light (Signal Tower) is tied into the Cycle Start of the CNC. That way, when Cycle start has been activated, the green light is on. Unfortunately, any cycle start will activate the green light, whether in Auto mode or MDI mode.
    You can try tying in the green light of the signal tower to the Spindle On signal, that way the light will be on only during spindle operation. Or the other option, which may be quite expensive, is to get some type of monitoring software, like Predator, or something.
    Feb 2007
    126
    thanks
    Thanks for your answer. Anyone else have any ideas which might work without reprogramming the ladder logic. Doesn't seem to be controlled by a parameter as I'd hoped.
    Dec 2003
    24223
    I see you have a duplicate post happening here :nono:
    I took it to be a Fanuc 15 from your other post, but it looks like I may be mistaken.?
    Al.
    Albert E.
    Feb 2009
    6028
    Pat light
    SV50 would be a 16 or higher. I've NEVER seen a 15 on a SV. Only way to change the status of the light is to change the ladder, or wire the light to an external M code.
    Feb 2007
    126
    thanks
    Quote Originally Posted by underthetire View Post
    You're right, it is an 18 control. I got in a hurry and just copied data from the CAP screen. I am an idiot.
    It was handy to be able to give my supervisor an answer in a timely fashion. Our maintenance man agrees with you.
    Thanks to all who answered me.
  1. New Wizard
    By Shinosky in forum Mach Wizards, Macros, & Addons
    Last Post: 04-26-2012, 02:15 PM
  2. Help, Mr. Wizard !!!
    By emexcee380 in forum Mori Seiki Mills
    Last Post: 03-11-2009, 12:31 AM
  3. Need Wizard
    By mungaro in forum Mach Wizards, Macros, & Addons
    Last Post: 04-12-2008, 10:59 PM
  4. Nesting Wizard, Mach3 internal wizard.
    By thuffner3 in forum Mach Software (ArtSoft software)
    Last Post: 03-05-2007, 03:38 AM
  5. Shapes Wizard
    By rweatherly in forum Mach Wizards, Macros, & Addons
    Last Post: 05-23-2006, 02:24 PM
