603,894 active members*
2,604 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Help me please!! Panasonic AC servo drive MCDHT3520 and motor MSMD082G1V test run
    Nov 2003
    4
    Hi all
    I have one set of Panasonic AC servo drive MCDHT3520 with motor MSMD082G1V, I am trying to run it without any success, I set all parameters to factory default and set it to velocity control mode, then followed all instruction on the section "Motor Trial Run" on the user manual, but it does not work.
    Does anybody has had any experiment with this servo system? I need some help urgently.
    Any help would be greatly appreciated.
    Aug 2014
    Re: Help me please!! Panasonic AC servo drive MCDHT3520 and motor MSMD082G1V test run
    i m also have problem for this model the motor is automatic shutdown after 3 second i need service manual pls.help
  1. Need Hel;!! Panasonic Dv 45 Servo drive
    By fabshop in forum Servo Motors / Drives
    Last Post: 11-20-2017, 05:00 PM
  2. Panasonic AC Servo Drive
    By rohitjain in forum Servo Motors / Drives
    Last Post: 10-04-2014, 03:18 PM
  3. Panasonic Servo Drive Problem
    By Mert-G in forum Servo Motors / Drives
    Last Post: 10-15-2007, 05:56 AM
